Changing from synthetic back to regular motor oil - Honda-Tech
Old 01-10-2012, 05:23 PM   #1
deerman2701's Avatar
Default Changing from synthetic back to regular motor oil
what do I have tto do in order to switch mmy 99 civic from full synthetic to regular conventional oil? I switched two oil changes aago and I would.like to go back to regular
Reason is. Since I.switched it seems I use more oil and now leaks.
I know I still will use oil with regular oil but.I would.rather spend 4 bucks a quart than breaking.the.bank spending like 8-10 bucks a quart every 1k miles.
Can I just use regular oil next time or.do I.have.to use some kind of engine flush.
deerman2701 is offline   Reply With Quote
Old 01-10-2012, 05:30 PM   #2
Default Re: synthetic to regular
based on my own experience synthetic oil really does not do much UNLESS you have used it since day one when the car has been driven off the lot ie brand new other than that id say you are safe to switch it back although you should get your leaks fixed
TerrenceDinesen is offline   Reply With Quote
Old 01-10-2012, 05:49 PM   #3
I would NOT recommend doing this. You can always buy a cheaper synthetic. I wouldn't switch and take the risk of causeing sludge. Not worth it in my opinion.
czum09 is offline   Reply With Quote
Old 01-10-2012, 06:08 PM   #4
Imnot really worried about sludge. I use seafoam every so.often.and I change my oil every month. 3-4k miles. I drive about 150 miles+ a day so I.don't.think sludge would.have time.to happen
Old 01-10-2012, 07:20 PM   #5
redm3turbo's Avatar
switch back and the leaks will get worse.
Its is highly reco'd to NOT switch that late in the game (with leaks etc) and you can NEVER go with one and then the other.
You went with Synth...now your stuck with it.
That or start buying gaskets for your motor.
redm3turbo is offline   Reply With Quote
Old 01-10-2012, 07:36 PM   #6
sde780's Avatar
Try a different brand or slightly thicker oil
sde780 is offline   Reply With Quote
Old 01-10-2012, 08:24 PM   #7
SiAutoX's Avatar
WTF? you can switch from conventional oil to synthetic oil every oil change and back again if you want. It will not damage, change, alter ANYTHING in your motor. Why do you think they developed "Synthetic Blend"? because conventional oil had properties that synthetic oil doesnt (lubrication) and Synthetic oil has properties that conventional oil doesnt (longevity). Only thing is higher mileage engines that have never been exposed to synthetic should shorten their first change after by about 500 miles to drain all the sludge the conventional oil out. Then you can flip flop back and forth as you want.
Dont want to take it from me? google it!
-or-
Take it from Mobile1
http://www.mobiloil.com/usa-english/...o_Mobil_1.aspx
SiAutoX is offline   Reply With Quote
Old 01-10-2012, 09:21 PM   #8
Mobile one sucks... just saying...
Just switch, gaskets seem to "swell" with conventinal oil
Hidenplanvew is offline   Reply With Quote
Old 01-10-2012, 09:41 PM   #9
TOO MUCH TORQUE's Avatar
Quote:
please ignore these two post...they have no idea what they are talking about.
YOU CAN SWITCH BACK AND FOURTH
TOO MUCH TORQUE is offline   Reply With Quote
Old 01-11-2012, 12:26 AM   #10
SiAutoX's Avatar
ive used Mobil1 nearly my entire oil changin life and never had an issue...... just sayin. They're the leader in synthetic oil for a reason.
Old 01-11-2012, 05:09 AM   #11
Got a friend at royal purple and he changes his oil every 5 to 6k mostly highway miles. He gets it a lot cheaper than we do. Save some money by not changing it so often. Thats one of the pluses of synthetic.
riceburner94si is offline   Reply With Quote
Old 01-11-2012, 06:39 AM   #12
Default Re: Changing from synthetic back to regular motor oil
IMO, just replace the oil leaking gaskets and stick with synthetic oil. You seem to maintain your car well. This will extend the engine's life.
Former User is offline   Reply With Quote
Old 01-11-2012, 07:55 AM   #13
switching back isn't a life and death thing but its not recommended. switching over can cause already minimal leaks to bigger ones. as yours seemed to.
but theres no problem in switching back and forth i just wouldn't.
fix your leaks first. even if you switch back it'll still leak.
Red_Army is offline   Reply With Quote
Old 01-11-2012, 08:55 AM   #14
KINGVEM^^ED6's Avatar
You can get mobil one at wal mart for 25 for 5 quart jug
KINGVEM^^ED6 is offline   Reply With Quote
Old 01-11-2012, 08:58 AM   #15
working in an autoshop for 5 years i heard both aurguments. i personally think it will be ok to switch back to conventional. you have to address those leaks either way tho.
just my two cents.
grease monkey1 is offline   Reply With Quote
Oil for high mileage accord Imaginethat238 Honda Accord (1990 - 2002) 6 02-27-2008 02:58 PM
okay to use regular oil after full synthetic ? redDAinteg Acura Integra 7 06-05-2006 12:17 AM
Ok to change from 10w-30 mobil 1 synthetic to high mileage oil? Bngo731 Acura Integra 3 02-01-2006 05:49 PM
Switching from Regular to Synthetic vinuneuro Tech / Misc 4 10-29-2003 07:49 PM
Synthetic Engine oil jordan88 Honda Civic / Del Sol (1992 - 2000) 9 06-07-2003 04:19 PM
Tags
2006, back, blend, change, changing, civic, conventional, element, honda, leaks, mobil, oil, regular, switching, synthetic, thicker
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
