Changed Thermostat/Spark Plug Wires Now Car Wont Start - Honda-Tech
Old 01-04-2013, 08:48 AM   #1
dizzi's Avatar
Default Changed Thermostat/Spark Plug Wires Now Car Wont Start
I had a cooling system problem about two weeks ago, and in [possibly] solving the problem, i created another one. I realized the thermostat was no longer opening up so i replaced it. While replacing the thermostat, i had to unhook the spark plug wire boots from the distributor so i could reach the thermostat housing. After changing the thermostat i put the thermostat housing back (ground wire also), and reconnected the spark plug wires. At first i accidentally had the wires in the wrong firing order so i thought that was initially why my car wouldn't start. After reconnecting them in the right order i couldn't get the 2nd one onto the distributor as it was bent up. So i went on and bought new wires altogether.... with the new wires now in the right order (at least i believe so) the car still does not come on. Before replacing the thermostat and spark wires the car came on with no problem... so what am i doing wrong here?
dizzi is offline   Reply With Quote
Old 01-04-2013, 08:59 AM   #2
The Grumpiest
grumblemarc's Avatar
Default Re: Changed Thermostat/Spark Plug Wires Now Car Wont Start
Double check that ground. That's where I'd start.
grumblemarc is offline   Reply With Quote
Old 01-04-2013, 09:03 AM   #3
Technical Hero
HondaPartsHero's Avatar
That and make sure they are in the right order
HondaPartsHero is offline   Reply With Quote
Old 01-04-2013, 09:06 AM   #4
dizzi's Avatar
Picture of my engine from distributor side
Old 01-04-2013, 09:08 AM   #5
dizzi's Avatar
triple checked the ground wire and spark plug wire order.... im not sure whats the problem as i didnt touch anything else.
Old 01-04-2013, 09:22 AM   #6
Swap'DShuttle's Avatar
If thats all that you did then the only thing it could be is that ground to the thermostat housing. Either something magically took a poop at the same time, or you touched something else important.
Car does not turn over? Cel light/fuel pump (car in general) does not light up/ turn on when in ON position? Or car does not start when engine is turning over?
(Post 420 bro! Ohhhhhhhhhh!)
Swap'DShuttle is offline   Reply With Quote
Old 01-04-2013, 09:38 AM   #7
dizzi's Avatar
Yea, hoping that something didnt somehow give out while i changed the thermostat. would seem strange. im certain i didnt touch anything else, only thing i removed to get to the thermostat was the lower radiator hose, the spark wires and the ground wire. all of which i reconnected and triple checked. The engine doesnt really seem to turn over. im no mechanic but the engine doesnt sound like one that is turning over yet not getting fuel or anything. more like its trying to turn over then starts coughing lol.
Old 01-04-2013, 09:39 AM   #8
angrysmileyface's Avatar
Possibly a toasted coil or ICM. I only did a tune up (cap, rotors and wires) and my coil died after 20 years of service.
angrysmileyface is offline   Reply With Quote
Old 01-04-2013, 09:42 AM   #9
So everything lights up on the dash, you can hear the fuel pump prime and it just sputters? I'd either have the coil tested or check resistance yourself.
Old 01-04-2013, 09:51 AM   #10
dizzi's Avatar
yep, i turn the ignition to (ll) all dash lights come on, the CEL comes on for 2 secs then turns off. I can hear moving parts for a few secs which im guessing is the fuel pump? Then i turn the ignition to (lll) the engine cranks twice then seems to cough. Sounds nuffin like the way it sounds when your simply just out of gas and the engine cranks and turns over but doesnt start.
Old 01-04-2013, 09:57 AM   #11
Yeah you'' hear a hum until the CEL turns off, thats the fuel pump. And if its turning over strong just coughing I'd check that coil resistance. First check to see if you have spark or weak spark. This video should help too.
https://www.youtube.com/watch?v=9K78XIhhjAQ
Old 01-04-2013, 09:59 AM   #12
dizzi's Avatar
also, i might as well throw in the fact that about a week ago my radio was bugging. after getting off work i sat in the car for about 2 mins and for whatever reason the radio seemed to reset. it went in and out without resetting a few times after as if it was losing power for whatever reason. not sure if its significant cause right NOW the radio, ac, dash lights, headlights, ceiling light, and fog lights seem to run fine but the car isnt starting.
Old 01-04-2013, 10:02 AM   #13
dizzi's Avatar
yup i hear moving parts as the CEL is on then it shut off as the CEL disappears... and thanks for the help bro i appreciate it. I'll follow the vid and check if the spark is weak. Then i'll see about testing the coil resistance.
Old 01-04-2013, 10:08 AM   #14
No problem dude. Good luck, and keep us updated.
Old 01-04-2013, 03:58 PM   #15
Technical Hero
Look at my picture again you have all 4 plug wires one cylinder off, should be like
Old 01-04-2013, 04:20 PM   #16
Holy ****! I really missed that! Good eye hondapartshero!
Old 01-04-2013, 06:01 PM   #17
dizzi's Avatar
Oh wow are u serious?? Im gonna run and fix them now!
Old 01-04-2013, 06:21 PM   #18
dizzi's Avatar
Quote:
I love u!!! Lol, damn i knew it had to be something simple i did! Thanks man... i didnt pay attention to the position of the distributor in that picture compared to mine... How did i miss that!
Old 01-04-2013, 06:23 PM   #19
dizzi's Avatar
Thanks again to both u guys for all the help.
92 Accord EX No Start Issue Blue93Dakota Honda Accord (1990 - 2002) 2 04-13-2015 05:27 PM
D15B7 Overheats and Eats Coolant after thermostat change EG92DX Honda Civic / Del Sol (1992 - 2000) 7 10-04-2012 06:28 AM
Cooling fans issue/questions FEAR6655 Honda CRX / EF Civic (1988 - 1991) 8 05-08-2012 05:26 PM
Won't start/replaced thermostat! BanzaiBeast Honda CRX / EF Civic (1988 - 1991) 3 05-14-2011 12:55 PM
Wrong thermostat = Blown head? Pele Honda CRX / EF Civic (1988 - 1991) 0 11-02-2002 04:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
