CEL, B18 swap form 99 Integra into 97 Civic EX
Old 12-12-2013, 08:14 AM
ClassyG's Avatar
Default CEL, B18 swap form 99 Integra into 97 Civic EX
Hello,
I bought a 97 Civic which had a b18 swap done. I drove it for the first week with no problems, then the check engine light(CEL) with the code P0420. The guy at autozone that ran the code told me its probably the primary 02 sensor. So I got a direct fit 02 sensor from amazon and swapped out the pre cat 02 sensor. Then cleared the CEL and after driving 50 miles the CEL came back on. I then figured it was the cat converter, so I got the cat replace and drove it over 100 miles before the CEL came back on. Im not sure what the problems is.
Any ideas or comments?
would be greatly appreciated.
Old 12-12-2013, 08:42 AM
kyden's Avatar
Default Re: CEL, B18 swap form 99 Integra into 97 Civic EX
have you tested the rear o2 sensor?
Old 12-12-2013, 01:34 PM
ClassyG's Avatar
Sorry, i didn't mention it before. I have also swapped the rear 02 sensor with the one I bought from amazon,but the light came back on after about 50miles.
Old 12-13-2013, 05:38 AM
kyden's Avatar
what cat did you get?
Old 12-13-2013, 07:04 AM
Marvin1985's Avatar
Sounds like the car is running poorly and causing the o2 to either go bad or not read because it's covered in crap
Old 12-13-2013, 08:10 AM
Technical Hero
HondaPartsHero's Avatar
Old 12-13-2013, 08:36 AM
ClassyG's Avatar
I got a OBD II high flow weld-on cat.
HAZARD_1310
04-23-2008 05:29 PM
SOKDO
10-12-2006 07:13 PM
3rdgenLS
03-14-2005 02:21 PM
Nero2007
11
07-28-2004 04:22 PM
Quick Reply: CEL, B18 swap form 99 Integra into 97 Civic EX
