Causes for injectors not spraying? - Honda-Tech
Old 05-08-2010, 03:06 PM   #1
FlewByU352's Avatar
Default Causes for injectors not spraying?
I have fuel to the rail, spark, compression, the motor cranks but it wont start. I am getting power to the injector connectors 12.5V on the one wire and 3.9V on the other. The injectors wont spray though. I kept cranking, checked everything, took a plug out to smell the cylinder for fuel and nothing. Pulled the rail off and cranked it nothing came out of the injectors. What causes them to not work? The ECU was perfectly fine last time it was running.
FlewByU352 is offline   Reply With Quote
Old 05-08-2010, 05:43 PM   #2
WeakSauce92's Avatar
Default Re: Causes for injectors not spraying?
clogged? otherwise bump
WeakSauce92 is offline   Reply With Quote
Old 05-08-2010, 06:04 PM   #3
reithhikaru's Avatar
What trigger a fuel injectors to spray when start-up? Crankshaft position sensor! If your motor is 95 or below , check your distributor. If it is a 96 or above, check the sensor behind the timing cover. when it is cranking it should read 1-3v, not exactly remember but not 5v steady.
reithhikaru is offline   Reply With Quote
Old 05-08-2010, 06:17 PM   #4
Check whether ECU terminal A23 is providing ground. If so, swap in a known good ECU.
Former User is offline   Reply With Quote
Old 05-08-2010, 06:52 PM   #5
FlewByU352's Avatar
its a 98+ JDM ITR swap going it a 97 civic ex
Old 05-08-2010, 09:38 PM   #6
FlewByU352's Avatar
ECU fried or ground bad or cam sensor I think one has to be the problem, maybe all IDK. No spark on 3rd cylinder also now, my cap and rotor are burnt a little. The reason I say cam position sensor is the motor needs either a crank or cam position and JDM motors have a cam not crank. It needs to know where everything is for the duty cycle to know which injector to open. The cam position sensor is located inside the distributor, maybe something fried hence the burnt cap and rotor and 3rd not sparking and maybe it burnt up the sensor? How should I check the ECU to make sure its grounded? Before I go buying a bunc of things I want to try and check everything to see exactly what needs to be replaced.
Old 05-09-2010, 02:57 PM   #7
FlewByU352's Avatar
any ideas?
Old 05-14-2010, 08:23 AM   #8
FlewByU352's Avatar
i'm at a stand still with no car, someone has to know whats up
93 Del Sol won't start, even with starting fluid Bipolarcivic Honda Civic / Del Sol (1992 - 2000) 30 04-10-2016 08:26 PM
NEED HELP!!!! no power to injectors solsquad27 Hybrid / Engine Swaps 4 05-16-2012 12:54 AM
Fuel gets to the rail but injectors wont spray Lmgrcivic Honda Civic / Del Sol (1992 - 2000) 8 09-25-2010 05:25 PM
d16z6 in 91 civic hatch wont start no fuel lovemyef Honda CRX / EF Civic (1988 - 1991) 6 11-17-2009 12:00 AM
car wont start(no fuel, no spark0 fcfromhell420 Acura Integra 12 04-12-2008 08:37 PM
Tags
1995, accord, civic, ecu, fried, honda, injector, injectors, odyssey, spray, spraying, triggers, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
