need help with ac compressor
Re: need help with ac compressor
If the pressure switch sees low pressure or to high a head pressure it will cycle the compressor off.
Even with a properly charged system the compressor can still cycle. You have a Thermostat attached to the outside of your Evaporator with a probe that goes down into the core of the Evaporator. When it gets to a certain temp it will cycle the compressor off. I have seen some T-Stats cycle the compressor off at 37 Degrees F. If it didn't and the Evaporator just got colder and colder it would freeze up and you would also probably get refrigerant back into the compressor in a form of a Liquid instead of a gas.
On days with a lower Ambient temperature such as 70 degrees F the A/C won't have as much load on it so it will run closer to capacity or to capacity a lot easier than a 90 degree day. At 90 degrees F you may notice the compressor doesn't cycle as its got a lot more load/strain on it.
This is at least how I understand it. I might be wrong so don't take it to heart. If I am wrong someone let me know.
You need a manifold gauge set. Measure the high and low side refrigerant pressures when the engine is idling at 1500 rpm. Also mention the temperature outside when the test is done. This information will help diagnose the problem. Did you recently add refrigerant to the system? Overfilling can cause the problem you are having.
Does the condenser fan run continuously when the A/C is on?
yes i think the condenser fan stay on with the ac. Will this moring i started her up and i trun the ac on it trun on fine compressor was on about more then 3-4mins. And i drove to the store came back home it started to the same thing. it will trun on and off ever 10secs.
Normal on/off cycling of the A/C system is controlled by the thermostat, which is plugged into the evaporator. When the thermostat turns the system off, the condenser fan turns off and the compressor clutch disengages. When the A/C system has run for a while, on/off cycling may happen every 20-30 seconds. This is normal.
If when your A/C system cycles off, the fan continues to run yet the compressor turns off, then there is a problem.
Check the refrigerant pressures is good i check that already. where is the pressure switch? and imma check the gap for the clutch to.
Did you check the clutch gap?
Did you check the pressure switch? This is done by BRIEFLY jumping the connector.
