Catalytic Converter on 99 Civi LE, How to replace
Old 03-28-2013, 03:26 PM
trader8825's Avatar
Icon2 Catalytic Converter on 99 Civi LE, How to replace
I am getting P0420 Engine code. Already replaced both Oxygen sensors. Can someone tell me how to replace Catalytic Converter. Is it very hard to do or Mechanics just charge to much for it. I was quoted $740 by a mechanic. but O'Reily has it for $178.
Old 03-28-2013, 03:29 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Catalytic Converter on 99 Civi LE, How to replace
Bolt off. Bolt on.
Old 03-28-2013, 05:13 PM
redm3turbo's Avatar
remove all the exhaust mainfold bolts off the engine...
remove the 2 bolts from the exhaust.
be careful with the exhaust mani bolts...they aren't on there that tight. with the exhaust bolts...get a torch or an impact. those are usually welded afast.
Old 03-28-2013, 07:45 PM
v!taminb16's Avatar
Put car on lift, grab wrench and loosen bolts, remove replace
Old 03-28-2013, 07:59 PM
jbpnoman's Avatar
Make sure you're getting the correct cat. The LE has the D16Y7, if I remember correctly, and some (if not all) have the cat integrated into the exhaust manifold. Verify what you need and what you're getting before buying anything.
Old 03-28-2013, 08:52 PM
Koko4's Avatar
Do it yourself - it's seriously quite easy. Make sure you have a breaker bar of some sort, because the bolts will be rusted as hell. I use the handle to my jack, and slide it over my 3/8ths socket wrench. Those D16Y7 manifolds are known to crack, underneath the heat shield, right where the "Y" of the exhaust manifold is..
Mishako129
06-14-2012 06:41 AM
5lugSlug
03-18-2006 03:20 PM
Cherchez La Ghost
12-29-2004 06:21 PM
MysticAzn03
02-19-2003 03:03 PM
Aaron M
06-15-2002 10:43 AM
Quick Reply: Catalytic Converter on 99 Civi LE, How to replace
