Catalytic converter - Honda-Tech
Catalytic converter
Old 06-13-2011, 05:22 PM   #1
Default Catalytic converter
would a code be thrown for a obd II b16a2 bad cat...or could i have a bad cat, with no code be throw...having acceleration pro's..just checking....maybe its clogged but would i throw a code? there are no codes presently, thx
justdoinme23 is offline   Reply With Quote
Old 06-13-2011, 06:04 PM   #2
redm3turbo's Avatar
Default Re: Catalytic converter
mine tossed a code...60 I believe.
ran perfectly, got great mpg...no noise...nada.
Threw a code and couldnt get rid of it except changing it...
redm3turbo is offline   Reply With Quote
Old 06-13-2011, 06:07 PM   #3
take the cat off if ur acceleration goes away clogged cat if it still there it another problem
95EG2 is offline   Reply With Quote
Old 06-14-2011, 09:47 PM   #4
There's a mod involving two spark plug defoulers you can do to trick the ECU into getting an acceptable reading from the secondary sensor. Take first defouler, drill through it. screw the 02 sensor into that, then screw those into the 2nd defouler, and that into the exhaust.
NotAJDMFanBoy is offline   Reply With Quote
Old 06-15-2011, 07:37 AM   #5
actually here is a link. need to do this to mine so I have it bookmarked. everything is running fine so I just want to shut the light off. don't want to miss any other codes that might show up.
http://www.civicforums.com/forums/22...on-w-pics.html
jumby is offline   Reply With Quote
Old 06-15-2011, 07:43 AM   #6
A bad cat will almost always throw code P0420.
Former User is offline   Reply With Quote
BAD CRANK SENSOR THROW CODE? 1yesfan Honda Accord (1990 - 2002) 7 04-06-2016 04:56 PM
Will a cat-back exhaust fix P0420? rowo87 Honda Civic (2001 - 2005) 8 03-31-2010 11:38 PM
Getting Code 67 in '98 DX. What else do I need to fix? spooncivic1 Honda Civic / Del Sol (1992 - 2000) 2 06-04-2007 11:02 AM
99 Civic EX Throwing Code 67. What to replace??? SOKDO Honda Civic / Del Sol (1992 - 2000) 2 10-12-2006 08:13 PM
CEL code 67 DVS Luder Honda Prelude 2 02-19-2006 10:31 AM
Tags
1995, bad, cat, catalytic, civic, clogged, code, comnverter, honda, ii, obd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
