Cat Converter died. Live in a non-emissions county, should I go test pipe?
Old 08-17-2010, 06:46 PM
EJeff8's Avatar
Default Cat Converter died. Live in a non-emissions county, should I go test pipe?
It's tempting to go straight. I don't need to worry about emissions. My converter died so it gives me a reason to do it. Or should I do a high flow cat? Me and my friend don't think the cat holds that much "back pressure" so it wouldnt throw my engine too far out of wack. A high flow cat in my problem would just be for sound purposes right? Opinions welcome.
I have a Y8 with stock header, dead stock cat and a catback Greddy EVO2 2.25" exhaust.
Old 08-19-2010, 01:24 PM
clean92ex's Avatar
Default Re: Cat Converter died. Live in a non-emissions county, should I go test pipe?
Depends whether your cars obd1 or obd2. Guessing from your pic its gonna be obd2, which has a post cat o2 sensor. Running a straight pipe is going to make your car run rich and possibly throw a cel. A high flow cat shouldn't do that and won't have your car running rich
Old 08-19-2010, 01:27 PM
EJeff8's Avatar
Ah. The secondary o2 does relatively nothing though right?
Old 08-19-2010, 01:29 PM
Retired Moderator
EsotericImage's Avatar
If you need a cat for visual inspection from a cop. Votionspeed.com sells fakes that are straight thru. A CEL eliminater will solve your CEL Problem.
Old 08-19-2010, 01:31 PM
clean92ex's Avatar
It still plays alittle role tho. I'm pretty sure it's gonna throw a code for your pre cat sensor not working properly, but it won't make it run much noticibly richer
Old 08-19-2010, 01:38 PM
EJeff8's Avatar
Hey, Eso! Just the guy I was looking for haha. I doubt a damn cop would ever want to bend down under my car. My dad had a high *** straight 350 and was never questioned about a cat. What's a CEL eliminator? And I might still go high flow, idk. What's your take? And how rich would I run straight?
Old 08-19-2010, 01:49 PM
lunareg's Avatar
it wont be terribly noticable performace wise, but you will notice that your going thru gas faster. honestly if your cat is bad right now you should already be throwing that cel.
Old 08-19-2010, 01:51 PM
EJeff8's Avatar
^I did a jump and it just gave me Cat converter, but nothing more specific than that.
EJeff8's Avatar
Does this mean that a straight really won't be too beneficial or too bad?
Old 08-19-2010, 01:55 PM
lunareg's Avatar
I meant the rich conditions, but that would also apply to straight pipe. The only thing you prolly would notice is that its louder.
Old 08-19-2010, 02:00 PM
-__-'s Avatar
my cat also died lol. i had severe power loss cuz it was very clogged. so i juts hollowed it out. my car is OBD-2 and im still throwing the catalytic converter code. Also running a little rich. I might jump back to obd-1
Old 08-19-2010, 02:04 PM
EJeff8's Avatar
yeah, this does turn me away from it. A high flow cat would keep the rich conditions fairly close to stock, will keep the CEL off and still allow me to keep a nice sound and maybeee a performance boost. I'll probably go high flow even though I don't need to pass emissions. It's just the best option I think.
Old 08-19-2010, 02:15 PM
lunareg's Avatar
yeah im not positive how it will work with a high-flow I havent used one before, but that o2 after cat is basically checking with the one on the down pipe to see if there is a difference in emissions. So the high flow would have to have some sort of exhaust cleaning put into it to keep the light off.
Old 08-19-2010, 02:30 PM
EJeff8's Avatar
^I think it's still a fully functional cat, just built for performance more than emissions. That's how people pass with them.
Old 08-19-2010, 02:36 PM
chucky420's Avatar
Get a straight pipe and a "check engine light eliminator". It's a little threaded bung that installs where the sensor used to go and then the sensor threads into it. It has a small hole allowing a smaller amount of exhaust to reach the sensor, effectively tricking it into giving a correct reading. I was scheptical, but I've seen them work on multiple cars. Eliminates the code 0420 (67) as long as your secondary HO2 sensor is still working. Noticeable power gain, increase in sound (louder). That sensor has no effect on fuel trim at all. It is just in place th monitor the catalyst. All fuel trim is controlled using the primary as a reference.
Old 08-19-2010, 02:52 PM
EJeff8's Avatar
^Cool. Well, now what I'm worried about is what "louder" truely is, because I like the sound my GReddy offers and what is the power gain realistically?
Old 08-19-2010, 07:43 PM
chucky420's Avatar
It's only a little bit louder, maybe a little deeper. As long as you have a muffler, it won't be too bad at all. The sound seems a little deeper at low rpm and I couldn't tell a difference at high rpm. Never seen before and after on a dyno, so I'm not sure about numbers. The power gain is best described by how your car feels when you're low on gas or if you inflate your tires above 40psi (a little quicker). To get an idea, drop your tire pressure to 25psi and go for a quick spin, then inflate to 40psi and compare. That's roughly the kind of gain in power I'm referring. You can feel the difference.
Old 08-19-2010, 08:34 PM
Da-Risin-Smoke's Avatar
Cat deletes change the powerband.
You lose some low end torque and gain more top end.
Old 08-20-2010, 11:47 AM
EJeff8's Avatar
^.This is what I've heard. Definitely tough to choose between.
REDTMNT
04-28-2009 08:58 AM
d16sandrail
10
02-23-2009 03:24 AM
no2unenolife
10-31-2005 03:08 PM
JamesQ
04-27-2004 04:14 AM
Sivik
07-26-2003 07:06 AM
Quick Reply: Cat Converter died. Live in a non-emissions county, should I go test pipe?
