98 ex/b16A swap - What A/C compressor bracket is needed to reinstall A/C system?
Ok well im in the process of putting a/c back in my 98 ex coupe. The car has a b16A swap. I have everything i need to put it in except for the compressor bracket and belt.Now my question is which bracket am i supposed to use for the a/c compressor?I will be using a compressor off an 2000 integra, I am asking for some info because i have read so much on the web already and everything i look at is all different and just confuses me I know i can use the 98 crv bracket or the delsol bracket that came with a b16, But are those my only options for the compressor im using or should i use a different compressor all together?...any info is appreciated
Re: Cant take the heat!...A/c questions inside
its been done numerous times but ill help since im here. not to sure about the integra compressor but on my civic with gsr swap i used the b20 ac bracket mount or you can get the dohc vtec del sol which is a little more pricy brand new. with that specific bracket i used the stock civic compressor, which will bolt up perfect, and use any b series ac belt( part # are different but some are shorter n some longer, but thats easy fix with the tensioner. also get any b series a/c tensioner, all the same. connect ports, flush, and fill.
Which crv bracket is the one i need because i was told that the 5 spd one and automatic one differ
okc
05-01-2011 07:56 PM
ANGELIQUE
03-27-2005 12:09 AM
ghettochild
11-27-2002 11:46 AM
