Carpet Dye Vs. Buying Black carpet - Honda-Tech
Old 02-08-2011, 11:26 PM   #1
Default Carpet Dye Vs. Buying Black carpet
I have an EG with stinky grey carpet, i want black carpet. Would it be easier and more cost efficient to clean my carpet and bye it with a bottle of black dye? or should just buy someone elses?
anzh86 is offline   Reply With Quote
Old 02-09-2011, 12:10 AM   #2
Winlight's Avatar
Default Re: Carpet Dye Vs. Buying Black carpet
why not just put brand new Ozite carpet?its $12 a roll and takes 2 rolls
Winlight is offline   Reply With Quote
Old 02-09-2011, 12:34 AM   #3
cant find a distributor in San Francisco
Old 02-09-2011, 12:35 AM   #4
Arthas's Avatar
How expensive would it be to dye your carpet? Ive been itchin' to dye my carpet black.
Arthas is offline   Reply With Quote
Old 02-09-2011, 12:52 AM   #5
looked up a local crafts store, they have dye for $5/tube. Probably would use 1-2 tubes.
Old 02-09-2011, 03:02 AM   #6
im trying to decide on same thing, letme know how it turns out if u dye it, ill be going from tan to black
i believe our only other option is stockinteriors.com and its gonna run up to $144 for premolded black
blacktibby07 is offline   Reply With Quote
Old 02-09-2011, 04:42 AM   #7
The Grumpiest
grumblemarc's Avatar
Quote:
Try RIT dyes. Not expensive but the result is not equal to what you think it will be. If you're trying to get black you'll only succeed in getting maybe a dark charcoal gray. My wife dyes fabrics all the time.
grumblemarc is offline   Reply With Quote
Old 02-09-2011, 05:04 AM   #8
g35silversurfer's Avatar
NOOOOO. do NOT use rit dye. Honda carpet is Plastic fibers!
and dont get aftermarket carpet... that's ghey, I don't care what anyone says about it, it's never going to satisfy you unless you just don't care about your honda.
Here ya go man:
http://www.ozhonda.com/forum/showthr...carpet../page9
and after you read all of that.... Here:
http://cgi.ebay.com/Jacquard-iDye-PO...item8263c402ef
and you have pm
g35silversurfer is offline   Reply With Quote
Old 02-09-2011, 07:22 AM   #9
macson's Avatar
What's the qualm with aftermarket carpet?
macson is offline   Reply With Quote
Old 02-09-2011, 07:25 AM   #10
The Grumpiest
Quote:
Quote:
Originally Posted by eg6.merrill View Post
that's ghey
Don't know what that means besides the obvious.
Old 02-09-2011, 07:30 AM   #11
macson's Avatar
Well the last thing I want is homosexual carpet.
Old 02-09-2011, 08:16 AM   #12
not even going to explain. if you want aftermarket carpet. Go for it.
Old 02-09-2011, 09:28 AM   #13
Linked's Avatar
i dyed my grey carpet black using rit dye and a big plastic tub for my EG
the carpe came out pretty good, i used 2 bottles of rit, bought some cleaner and such to clean it before hand
the only bad part about the carpet is the plastic trim at the bottom of the door jamb is like held in by clips you will most likely break off, if those arent fixed your carpet will pull back around the door jamb
Linked is offline   Reply With Quote
Old 02-09-2011, 09:33 AM   #14
Importdj67's Avatar
I tried ritz about 7 bottles in a big trash can... did not work for me.. still was grey after a day sitting in the tub..
Importdj67 is offline   Reply With Quote
Old 02-09-2011, 10:14 AM   #15
READ...
Here ya go man:
and you have pm
Old 02-09-2011, 10:44 AM   #16
pityocamptes's Avatar
Checker Auto sells a carpet paint. I used it years ago on an older Hyundai (getting ready to sell), and it came out pretty damn nice!!!
pityocamptes is offline   Reply With Quote
Old 02-09-2011, 10:51 AM   #17
rel
rel's Avatar
it all depends if money is no object to you, if it is like me take the carpet to the car wash spray it go to autozone and get the carpet spray i think duplicolor makes it and spray it last a long time just makes the carpet a little crunch but u wont see it
rel is offline   Reply With Quote
Old 02-09-2011, 10:54 AM   #18
Icon6 Re: Carpet Dye Vs. Buying Black carpet
Quote:
Yea, thats the stuff. It works best of you REALLY clean the carpet out. I then laid the carpet out and did one light coat, let dry, ran my fingers through the fibers to break up the "crunchyness" and then applied another thin coat, and repeated several times. Carpet came out very nice and was not a big block of "crunchy" fibers...
Old 02-09-2011, 10:58 AM   #19
Luis.'s Avatar
I'd rather rock no carpet, OEM or nothing!
Luis. is offline   Reply With Quote
Old 02-09-2011, 11:35 AM   #20
macson's Avatar
No, please do. I was being serious, actually, as I've been looking into it. Issues with fit, quality...?
Old 02-09-2011, 01:44 PM   #21
yessir !
1. OEM is best. Best quality, best fitment, best EVERYTHING.
2. Aftermarket doesn't fit right. They're only "generally" molded. Not Exact.
3. Aftermarket carpet doesn't have holes cut out already. So if you don't already have some of the OEM carpet laying around to use as a template. your screwed.
4. OEM is Best. and JDM is even better, because Japan kept almost all the cool high end goodies for themselves. That's a huge reason ppl go after and spend $$$ on jdm parts. There's no better quality.
5. you can find a good used carpet. it's possible.
6. I just Pm'd you to help you out.
Old 07-06-2011, 05:18 PM   #22
jserman's Avatar
bump for some good info
jserman is offline   Reply With Quote
Old 07-06-2011, 07:03 PM   #23
I dyed my carpet a few weeks ago I used about 5 bottles of right dye boiled salt water and through it in a 35 gallon tub and let it soak in there for 3 days came out great still held up I thought once it rained my wet shoes would mess it up but it didn't best 20$ I ever spent
Cresendo is offline   Reply With Quote
Old 07-06-2011, 07:04 PM   #24
Rit dye****
Old 07-06-2011, 07:08 PM   #25
renewing my carpet, which is a good dye? dc4teg95 Acura Integra 9 02-11-2011 07:57 AM
wtb: black integra 2 door carpet patrick4588 Southeast (Sales) 11 10-03-2008 06:34 AM
Spray Paint or Spray Dye for carpet/vinyl hanskies Honda / Acura 4 05-17-2008 05:32 PM
?/dying carpet from gray to black?? twotalefox Honda / Acura 2 06-07-2006 11:36 AM
pics of factory black/grey interiors? kyler Honda CRX / EF Civic (1988 - 1991) 5 03-18-2002 09:59 AM
Tags
auto, autozone, black, buy, cadillac, carpet, cars, cts, dye, dyeing, francisco, hondatech, las, part, san, tan, vegas
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
