Car wont start: relay clicking, headlights turn off electronics help! HELP! - Honda-Tech
Old 08-28-2007, 10:28 PM   #1
turbotime's Avatar
Default Car wont start: relay clicking, headlights turn off electronics help! HELP!
Ok out of nowhere my car wont start anymore. I open the door, interior light comes on, put key in ignition, courtesy chime sounds. Turn key, computer makes a clicking noise and there is a tappin/scratching coming from the front right river footwell area which i am assuming is some sort of relay....all the instrument lights dim and flicker.
Turn on the headlights, all the lights and instrument cluster go out completely car doesnt even click or anything when i try to turn it on. Press brake pedal, similar situation, instrument lights go off completely, car wont even make a noise when i try to start it. Remove foot from brake, interior lights and instrument lights come back on, car still wont start but at least teh relay makes noise when i try and turn it over....
What the hell is going on here? Car was fine 5minutes ago! is the main relay dead? Is the battery dead? WTFFfff PLEASE HELP!!!!
turbotime is offline   Reply With Quote
Old 08-28-2007, 10:34 PM   #2
HT White Ops
Sounds like your battery is dead.
You could also have an alternator problem, but get a jump start first.
Eran is offline   Reply With Quote
Old 10-29-2007, 03:22 PM   #3
_decker's Avatar
Default Re: (Eran)
Im also having this problem in my 93 hatch. I left the lights on overnight and when I tried to jump start the car, it wouldn't turn over. I get the chime, and the lights on the cluster come on and when but when I push in the clutch and turn the key, there is a clicking/humming noise from the left lower dash, that's it. I got the car to turn over for about one second one time then it seems like it had no more juice, but it was hooked up to another car.
The battery is about 6 months old and the alternator is about a year old. I checked the grounds and the connection to the starter and everything seemed ok. Im thinking is the starter but does anybody else have and idea of what it could be?
_decker is offline   Reply With Quote
Old 11-29-2007, 04:46 PM   #4
TruckracerV's Avatar
Check the actual cables, i just had this problem on my nissan and needed to replace cables, no probs since
TruckracerV is offline   Reply With Quote
Old 11-29-2007, 06:55 PM   #5
eskimo10's Avatar
I agree with both. I have personally had my alternator take a crap on me and that had exactly the same symptoms you are describing. Also I worked on a neon that had similar symptoms and it turned out to be the battery wire to the starter that was frayed and melted. I would start with both of those. Check your wires first if they're fine, try and get a jump start, if you start it up then you could have an alternator problem like the voltage regulator taking a crap on you or something. Hope this helps!
eskimo10 is offline   Reply With Quote
Old 11-29-2007, 08:34 PM   #6
civic_coupe_585's Avatar
try cleaning your terminal wires with some sand paper until you can see copper, then clean off the terminals, then use battery terminal protectant to see if its just corrosion. it could be your ignition [the electronic part] mine **** the bed too. there was a recall for the prelude and accord but not for the civic. junkyard the part too it'll deff. be alot cheaper then the stealership they were asking $520 for just the part. do it yourself too its pretty easy. take apart the column and then disconnect the harnesses there should be like 3 of them.
civic_coupe_585 is offline   Reply With Quote
Old 11-30-2007, 01:09 PM   #7
RyanG's Avatar
Default Re: Car wont start: relay clicking, headlights turn off electronics help! HELP! (turbotime)
check all of your grounds to make shure that they are all snug and secure
RyanG is offline   Reply With Quote
Won't start... nothing working VTEC_Viking Honda Accord (1990 - 2002) 8 01-07-2017 05:54 PM
94 EX wont turn over, good battery, no solenoid click and weird humming, etc...help! Popsgarage Honda Accord (1990 - 2002) 0 10-10-2015 08:36 PM
97 prelude won't start - battery ok; no dashboard lights, windows, or turn signals frequentc Honda Prelude 13 01-31-2012 09:44 PM
main relay wont click....car cranks but does not start.... JDMPHILEP91 Honda Accord (1990 - 2002) 3 09-13-2009 07:04 PM
Just bought a new car, but it wont' start... Help? Tr0LL Tech / Misc 6 03-06-2003 10:57 PM
Tags
05, civic, clicking, clicks, crx, dash, dim, e46, honda, ignition, jump, lights, relay, sound, start, starter, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
