car wont start after it over heated. - Honda-Tech
Old 04-02-2012, 03:58 PM   #1
Default car wont start after it over heated.
so my friend bought a 96 civic hatch the other day. We were driving it back have and it over heated (hour and a half of driving). Pulled Imy the gas station and I checked it out. No coolant what so ever. also found out that the thermostat wasn't working and was closed the whole time. We tried filling the radiator up with water and still no start. It had the cel on. 4 codes. Engine coolant temp sensor, catalytic converter, misfire in cylinder 1 and 3. It cranks but won't start.fuel pump is working. Idk what to check next. I'm kinda new at this and still trying to learn. where to i go from here? What else can I check? What can it possible be? PLEASE HELP!!!
freshCROOKS is offline   Reply With Quote
Old 04-02-2012, 04:00 PM   #2
dE.fUsEd's Avatar
Default Re: car wont start after it over heated.
Ouch. Check the oil, what color is it?
dE.fUsEd is offline   Reply With Quote
Old 04-02-2012, 04:21 PM   #3
Silvertune's Avatar
Time for a new motor.
Silvertune is offline   Reply With Quote
Old 04-02-2012, 06:34 PM   #4
yep check oil. if your coolant is all gone though, i'd say your motor is too. thats got blown headgasket written all over it
Bradshaw is offline   Reply With Quote
Old 04-02-2012, 06:55 PM   #5
thats why i never use water because it just boils out in the summer and freezes and cracks your block in the winter....always use anti-freeze
Cmoya07 is offline   Reply With Quote
Old 04-03-2012, 10:46 PM   #6
should I replace the head gasket or just get another motor.
Old 04-03-2012, 10:49 PM   #7
Oil looks fine
Old 04-03-2012, 11:06 PM   #8
furious94ls's Avatar
Most likely it's done.
furious94ls is offline   Reply With Quote
Old 04-03-2012, 11:46 PM   #9
The motor isn't scrap yet. Take the head off. Look for cracked cylinder walls. It's time to find out just how bad you guys screwed up that motor.
jbpnoman is offline   Reply With Quote
Old 04-03-2012, 11:55 PM   #10
drain the oil, if its milky than you have blown the head gasket. Other than that the only other symptoms of those codes would be bad plugs/spark, or a clogged cat. But I would go ahead and assume you will have chocolate milk when you drain the oil. Like stated above pull the head and see what kind of damage you have done to it. Most likely it will be cheaper to just replace the motor.
Voodoo7 is offline   Reply With Quote
Old 04-04-2012, 04:13 AM   #11
Seagull Management
94EG8's Avatar
Quote:
Overheated aluminum block for an hour and a half is absolutely scrap. You can almost definitely get it to run again, but it will take a oil at a ridiculous rate.
94EG8 is offline   Reply With Quote
Old 04-04-2012, 06:01 AM   #12
Quote:
What? The way I read the OP was that it was driven for an hour and a half, which the OP thinks is what caused the overheating. If he/his friend actually drove the car for an hour and a half with it overheating, they need to sell it to the junk yard, and use what little they get for it to buy a bicycle. What kind of moron drives a car for an hour and a half with it overheating?
Old 04-04-2012, 07:58 AM   #13
Seagull Management
94EG8's Avatar
Does this answer your question?
It wasn't mine, I just got hired to sort it out one time. It was driven overheated about that long. Temp gauge didn't work, guy didn't notice it was overheated till he saw smoke coming from under the hood. Kept driving because he was scared it wouldn't start if he shut it off.
Old 04-04-2012, 09:00 AM   #14
dE.fUsEd's Avatar
Quote:
Originally Posted by freshCROOKS View Post
Oil looks fine
I would buy a compression tester and then a leak down tester.
Unhook the CPU fuse under the dash, and do a compression test.
If bad compression, proceed to do a leak down.
They are both VERY easy to do.
Old 04-04-2012, 09:01 AM   #15
dE.fUsEd's Avatar
Holy crap.
Old 04-04-2012, 10:14 AM   #16
The temp gauge wasn't working so Idk how long we been driving it while over heating. About an hour and a half later, it started smoking and died out. Don't have to to check it today but most likely this weekend.
Old 04-04-2012, 02:39 PM   #17
Oh.
My.
God.
Go get a new motor out of a junk yard. You're SOL.
Old 10-28-2012, 11:07 PM   #18
Holy Smokes!
I wont use water anymore.
Jiyusan is offline   Reply With Quote
Old 10-29-2012, 09:03 AM   #19
Fnix's Avatar
Is there a way to have a block tested and see if it is still good after overheating?
Fnix is offline   Reply With Quote
Old 10-29-2012, 12:12 PM   #20
damn thats shitty, yep time for a new engine IMO i would NEVER buy a car with the heat gauge not working thats just sketched out
HondaMyWayOfLyf is offline   Reply With Quote
1995 Accord Coupe head problem shinobiu Honda Accord (1990 - 2002) 2 11-29-2016 06:45 PM
Mysterious intermittent overheating on 2005 Civic LX radfanjam Honda Civic (2001 - 2005) 5 06-24-2016 08:14 PM
Overheating problem bbrian Honda Civic / Del Sol (1992 - 2000) 14 08-20-2014 03:23 AM
God I hate VW DBAl General Discussion and Debate 64 03-20-2009 12:27 PM
Low idle issues with JDM B18C motor/air bubbles in coolant? entityzero Honda Civic / Del Sol (1992 - 2000) 6 03-26-2007 08:44 PM
Tags
car, chevy, civic, crv, engine, find, heat, honda, odyssey, overheat, overheated, start, starts, tahoe, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
