Speedometer and electronics stop working?
Old 12-20-2009, 12:58 PM
Jonathannx2's Avatar
Icon6 Speedometer and electronics stop working?
When I shift to certain gears my speedometer drops down to zero and my stereo stops working briefly and then comes back up when I am finished shifting.
It usually happens when I shift from 1st to 2nd. Sometimes on other gears too.
Any ideas on what is wrong and a fix?
Thanks in advance.
Old 12-20-2009, 03:19 PM
1siceg92's Avatar
Default Re: Speedometer and electronics stop working?
does the tripometer stop when whe the speedo craps out
Old 12-20-2009, 07:17 PM
I'm not sure if it does.
By the way, I just installed a short ram intake on my car yesterday. I never had this problem until today.
Old 12-21-2009, 10:38 AM
Anyone have any ideas?
Old 12-21-2009, 10:42 AM
MiG-21 superfan
builthatch's Avatar
yeah, when your engine rocks from shifting, a poor connection somewhere is being affected. you have to check all of your grounds and battery connections, ie not just on the battery but check your main power supply in the underhood fuse box, etc.
you have a lose connection somewhere. now might be a good time anyway to redo all of your engine grounds and battery power connections/terminals/etc.
Old 12-21-2009, 10:45 AM
Alright I'll check it out.
I know I need new battery terminals, mine are really corroded.
Old 12-21-2009, 10:51 AM
MiG-21 superfan
builthatch's Avatar
they could very well be your issue. make sure you check the connections of all your engine grounds too. chassis to battery, chassis to thermostat housing, valve cover to rad support, transmission to frame rail, and any other additional grounds that might be on your car IE intake manifold, etc. if you redo the battery terminals, you might want to look into the felt battery terminal o-rings to go onto the post before you attach the terminals. and your other grounds might need new terminals, new wires, or a simple sand job on the contact areas (under bolt head, both sides of terminal, etc)
Old 12-21-2009, 10:53 AM
Alright, will do. Thanks for the help man.
Old 12-21-2009, 12:32 PM
1siceg92's Avatar
un plug and chec the vss its under the intake on the top of the trans. un clip and chec as he said for anything werd . do you have a codes?(obd1 2 or 0?) be cause if you do its the vss sensor but if its intermintent then its a ground or the wires or conection to the vss or the cluster itself
Old 12-21-2009, 01:04 PM
MiG-21 superfan
builthatch's Avatar
it's greater than that...he said his stereo stops working too, so it's an overall 12V power issue.
Old 12-23-2009, 06:57 AM
1siceg92's Avatar
true true
Jakeumm
Honda Civic (2001 - 2005)
08-02-2016 01:19 PM
GPC91
05-07-2013 09:06 PM
sdots24
Honda Motorcycles
12-16-2011 09:41 AM
Tip14
12-27-2007 01:13 PM
samurablaze
11-08-2005 06:31 PM
Quick Reply: Speedometer and electronics stop working?
