car squeaks and sound like metal grinding while driving
Old 01-11-2009, 11:38 PM
Ritchie's Avatar
Default car squeaks and sound like metal grinding while driving
I'm having a problem with my 92 VX squeaking while driving. Before it would just squeak a little, but starting to notice it is squeaking a lot in the front passenger side on little bumps. Also, while turning left or right, I can hear some sort of metal grinding. Having trouble with it and tried searching. Car doesn't have power steering and was wondering what could cause this problem? Thanks.
Old 01-12-2009, 08:10 AM
92_civic's Avatar
Default Re: car squeaks and sound like metal grinding while driving
check your brakes...could be the pad wear indicators...and yes they can make noise without the brakes being applied
Old 01-12-2009, 08:28 AM
bsixteener's Avatar
The squeak is more than likely a suspension component. But towards the metal grinding noise I just had this happen to my car and when I checked the pad and they were fine the culprit was the metal clips that hold the brakes in place, one of the tabs had bent and was imbeding onto my rotor. I removed the tab and the problem was gone. Hope i've been of some help.
Old 01-12-2009, 08:33 AM
Black4thgenEF's Avatar
How bad is the noise? Can you feel it through the steering wheel? Have your wheel bearings ever been replaced. When mine went, it started with whining on turns but gradually got to the point when it would while going straight and grind when turning. Has the noise been gradually getting worse or did it just start one day?
Old 01-12-2009, 08:58 AM
Mr.Chow's Avatar
brakes...and or suspension bushings
Old 01-12-2009, 10:50 AM
Ritchie's Avatar
Yeah, the noise is becoming more and more noticeable. I'll have to wait until the end of the week to check on the metal clips by the brake pads. Wheel bearings have not been change. There are times when I press down the front of the car, the car would squeak. Could there be a problem with the shocks?
Old 01-12-2009, 11:03 AM
marcs1337's Avatar
balljoints
Old 01-12-2009, 11:04 AM
slammed4dreg's Avatar
did u ever have power steering or did it just go away? it could be the shocks or brakes, clips or it could be the metal dust cover thats behind the rotor. is the car dropped?
Old 01-12-2009, 04:33 PM
Ritchie's Avatar
I don't think the car came with power steering option. It is lowered on ground controls w/ stock shocks. If it was the suspension, could it be possible to reuse the ground controls and getting new shocks?
Old 01-14-2009, 09:54 AM
Ritchie's Avatar
Bump. Anyone know if it is alright to reuse the ground controls if I buy a new set of shocks?
Old 01-14-2009, 10:07 AM
DTA-Zombie's Avatar
yes you can reuse the ground controls
I'd check your axles first - the other thing is the little brake dust guard thing pressing against your wheel or the rotor - also check any side skirts and such just to be sure...
Old 01-14-2009, 10:23 AM
kaluwa3's Avatar
Originally Posted by Mr.Chow
suspension bushings
Old 01-14-2009, 10:33 AM
Ritchie's Avatar
Alright cool. I'll look over those this week. As far as the GCs, will it be alright to install it with some koni shocks?
Old 01-14-2009, 10:40 AM
95civic 4door lx's Avatar
.....get ur *** under the dam car and look, push pull on everything to see if anything is loose or out of order. check first!!!!!!!you want someone to tell you what it is before even looking and seeing.
Forrest04
Honda CR-V & Element
04-16-2014 11:50 AM
D7_62
11
12-12-2010 07:22 PM
96f22b2
10-06-2008 03:58 AM
LX4CYL
01-05-2004 09:34 AM
Quick Reply: car squeaks and sound like metal grinding while driving
