Car Sputter and Backfires? help?? - Honda-Tech
Old 05-10-2009, 03:02 PM   #1
Default Car Sputter and Backfires? help??
when im driving down the road the car if fine, then when you go to accelerate harder than normal everyday driving from a stop or while driving, the car shutters and backfires then when you let off the gas it goes back to normal. it runs perfect other than that. any help? thanks its a h22a in a del sol.
jdmboy94 is offline   Reply With Quote
Old 05-10-2009, 03:16 PM   #2
TravisCadello's Avatar
Default Re: Car Sputter and Backfires? help??
ECU problem maybe any CEL's? check the TPS sensor.
TravisCadello is offline   Reply With Quote
Old 05-10-2009, 04:41 PM   #3
no there are no Cels. ill check it but its driving me nuts, it runs perfect till you give it more gas. then it starts and you let off and it stops? i dont know what else it could be?
Old 05-10-2009, 04:45 PM   #4
civic_driver's Avatar
Have you checked the timing, both mechanical and ignition?
civic_driver is offline   Reply With Quote
Old 05-10-2009, 05:58 PM   #5
yea i checked the timing and it was good?? it ran fine the other day. it just started doing it?
Old 05-10-2009, 06:56 PM   #6
Probably something wrong with the dizzy.
Old 05-10-2009, 07:14 PM   #7
yea,^^^
Old 05-10-2009, 07:15 PM   #8
or clogged fuel injectors or fuel filter.
Old 05-10-2009, 09:14 PM   #9
i just put some injector cleaner in it yesterday and changed the fuel filter as well. then tonite i went to leave my girlfriends house and it wouldnt start. it just turned over but nothing. no CELs, fuel pump is priming, just put injector cleaner in it, fuel filter, replaced the ignition coil, it has the msd on it, spark plug wires.
Old 05-11-2009, 05:23 PM   #10
bump?
Old 05-11-2009, 07:36 PM   #11
check and clean the VTEC solenoid.....it sounds like theres a possibility you fryed your ECU also...that happened to me....its almost like its bogging out...try a different ECU preferably a stock one
hheard15 is offline   Reply With Quote
Old 05-13-2009, 06:03 AM   #12
los12's Avatar
bumpp because my car is doing the same thing
los12 is offline   Reply With Quote
Old 05-13-2009, 08:02 AM   #13
PphamEK's Avatar
check the fuel pressure. my buddy had a h22 eg and that was the problem
PphamEK is offline   Reply With Quote
Old 05-13-2009, 07:52 PM   #14
YangFlavor's Avatar
same thing happen 2 me too
YangFlavor is offline   Reply With Quote
Old 05-13-2009, 08:06 PM   #15
ok well today i bought new msd spark wires. and i have the blaster 2 coil on the car. and the wire going from the coil to the dizzy was messed up and i found it out the hard way lol, i went to grab the wire and it shock the s**t out of me, i replaced all the wires. and it helped out alot but it still backfires and sputter a little bit at high rpms? i put some fuel system cleaner in it and injector cleaner, so hopefully that will clear the rest of it up.
96 civic with exhaust backfire axis11 Honda Civic / Del Sol (1992 - 2000) 14 12-14-2011 09:02 PM
Help: 97 crv backfire?! slcivic96 Honda Element & CR-V 2 10-01-2010 07:58 PM
b18a1 swap crx backfiring and hesitating when at idling temperature cheesyrex Honda CRX / EF Civic (1988 - 1991) 4 11-30-2009 03:23 PM
Exhaust Backfires?? scrooge Honda Civic (2001 - 2005) 2 09-07-2008 07:17 PM
INTAKE MANIFOLD BACKFIRES-97 civic LX pattisapyro Honda Civic / Del Sol (1992 - 2000) 2 11-15-2003 07:15 AM
Tags
99, backfire, backfired, backfiring, car, civic, clogged, driving, filter, fuel, honda, integra, ls, sputtering, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
