Chipped ECU Problem.. CODE 24????
Hello everyone.. I have a problem with my chipped ecu P28.. its been working just fine. Tuning with CromePro and Datalogging worked just fine, but yesterday the check engine came on and it says Code 24(Yes 24)???? Crome says Code 24 Unknown. I tried everything to make it work.
First I took the chip jumper out and the light went out and no check engine, so I figured its something with the chip. I turn the ignition on and the check engine comes on and stays on. I found every list on codes on the internet and none of them have a 24, just goes from 23 to 25.
I tried uploading different maps, running from just chip or just emulator. Nothing seems to work. I recheck my ecu and touch every lead on the chip and chip parts with a soldering gun just to make sure it has a good connection, but still nothing.
If someone has any ideas please chip in. Thanks
Re: Chipped ECU Problem.. CODE 24????
Bump. I'm getting the somewhat of the same code. no idea what's going on. it is my first b18 engine, and I don't know how to tell what kind of ecu I have there are no markings on it. I'll report in if I can find anything also will be checkin back good luck brotha.
Will missing capacitors at c51 and c52 and also the jumper missing at j1 cause CEL for ELD "Code 20"
brixity
07-17-2005 01:40 AM
