Car shakes at 40mph +
Old 01-24-2005, 06:52 AM
black sohc civic's Avatar
Default Car shakes at 40mph +
My car shakes violenty from 40mph and up. The whole car and steering wheel shakes? Anyone know the cause? I was told it was a bad axle? Didnt hear any clicking noises when turning, at low speeds the car is fine. Any help is appreciated...
Old 01-24-2005, 06:53 AM
Risky Business
BauleyCivic's Avatar
Default Re: Car shakes at 40mph + (black sohc civic)
Wheel bearing, alignment, bent rim, bent sunspension component, uneven tire pressures...could be a bunch of things...
Have you hit any curbs recently?
Old 01-24-2005, 06:56 AM
Default Re: Car shakes at 40mph + (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Wheel bearing, alignment, bent rim, bent sunspension component, uneven tire pressures...could be a bunch of things...
Have you hit any curbs recently?</TD></TR></TABLE>
didnt hit anything recently, i actually just bought this car off a seller on here. didnt notice it that bad because i only test drove it on local streets.
no bent rims
tire pressures are all even
i do notice the car pulls to the left a little
Old 01-24-2005, 06:57 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black sohc civic &raquo;</TD></TR><TR><TD CLASS="quote">
i do notice the car pulls to the left a little </TD></TR></TABLE>
Get an alignment, and see if that fixes it.
Old 01-24-2005, 06:58 AM
Mr. Badwrench
boostedcivicsir's Avatar
if the shaking only exists while you are on the gas, it is probably a bad inner joint. being from NJ, you may have a build up of snow on the inside of your wheel if this just started happening. but if those 2 arent close, start with balancing your wheels and go from there.
Old 01-24-2005, 07:30 AM
AutoXer's Avatar
Get an alignment, and see if that fixes it.</TD></TR></TABLE>
And a wheel balance too.
Does it shake or pulse when on the brakes? Warped rotors can cause vibration, but you'd feel it while braking as well.
Old 01-24-2005, 08:05 AM
Risky Business
Default Re: Car shakes at 40mph + (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
Can warped rotors cause vibration when you're not on the brake pedal?
Old 01-24-2005, 08:33 AM
hawaiianbro's Avatar
How do you know that the rims aren't bent?? My cars rims are bent but it doesn't start vibrating until around 60 and then when I get past 80mph it becomes smooth again. Try putting on some stock wheels and see if it still vibrates. If it doesnt than thats your problem if it does, than one other response i didnt see was to check your motor mounts? Just a thought.
Old 01-24-2005, 08:50 AM
Del Sizzle's Avatar
I'd go with getting the tires balanced, that worked for me.
Old 01-24-2005, 08:55 AM
civicboisi's Avatar
Also, get your front end checked out...but sounds like you have shitty tires...bad or camber weared tires cause this more often then bad parts, but you never know...
Old 01-24-2005, 09:01 AM
AutoXer's Avatar
Can warped rotors cause vibration when you're not on the brake pedal?</TD></TR></TABLE>
Yes, I've had it happen a few times. It's rotational mass, so being warped can cause vibration; but since the mass is pretty evenly distributed from the center, and has a fairly small diameter (as opposed to a tire) they have to be pretty bad to cause vibration at speed.
zach1288
20
09-18-2007 08:17 AM
hmongboyLS
05-04-2006 10:41 AM
markski037
01-20-2006 02:19 AM
theharlequin
03-18-2004 12:36 PM
Krnbk2
05-12-2003 09:03 PM
Quick Reply: Car shakes at 40mph +
