Car running rich, black smoke and soot from exhaust
Old 01-19-2016, 11:00 AM
Circaskaterr's Avatar
Default Car running rich, black smoke and soot from exhaust
So as the thread title says my car is running rich. Its a 95 hatchback with a D16Z6. I have replaced the FPR, fuel filter, spark plugs, O2 and Cleaned the K&N filter already. The car was throwing a CEL before, code 43, but since changing all that stuff and resetting the ECU the code has not returned but the car is still running rich.
Old 01-19-2016, 11:08 AM
Former User's Avatar
Default Re: Car running rich, black smoke and soot from exhaust
Measure the fuel pressure and check for a stuck open fuel injector.
Old 01-19-2016, 11:32 AM
is there an easy way to check to see if an injector is stuck open?
Old 01-19-2016, 11:34 AM
Remove fuel rail with injectors. While securing the injectors in place, turn key to ON(II) [engine off). No injector should spray fuel.
Old 01-19-2016, 11:43 AM
Tegra206's Avatar
Old 01-19-2016, 11:48 AM
delsolintegra's Avatar
There may be a hairline crack in the exhaust manifold behind the O2 sensor bung hole. This will read as a lean condition and cause the ECU to send more fuel. If so a cheap ebay header seems to be the way to go.
Old 01-19-2016, 12:01 PM
Did the injector test and no fuel came out so im guessing somthing is causing me to have high fuel pressure? I dont have a kit to test the exact number available but if I need to i can go out and get one
Old 01-19-2016, 03:08 PM
I never narc'd on nobody!
NotARaCist's Avatar
You can rent the fuel pressure testing kit at your local parts store. You can also buy something simple like this if you want a more permanent solution.
Is your car stock? Any modifications? Unmodified P28 ECU? Original engine?
Old 01-19-2016, 03:39 PM
Also definitely look into this^
Old 01-19-2016, 04:30 PM
Not the original engine, the ECU is an unmodified P28 though. Only mod is an exhaust everything else is stock.
Would I be able to feel any exhaust coming out around the bung if there is a hairline crack there? Also I dont know if this stuff matters, but I have also checked the ignition timing with a timing light and its spot on and the problem kind of showed up out of no where, It wasnt a gradual thing. Ill go get a fuel pressure test kit tomorrow when I have some daylight and come back with the numbers I get.
Old 01-19-2016, 05:45 PM
Do you see a crack in the header? If so, post a picture.
Also, if you see the CEL turn on while driving, pull over and leave the engine running while you jump the service connector.
Old 01-20-2016, 11:14 AM
no cracks in the header didnt feel exhaust coming out anywhere near the gasket either
Old 01-20-2016, 12:09 PM
Tegra206's Avatar
some header cracks you won't see unless you take it off and inspect it.
Old 01-20-2016, 12:38 PM
I agree and this type of manifold crack is common to the 93-95 D16Z6.
It's on the side of the manifold close to the block and pinhole thin.
Old 01-20-2016, 01:25 PM
Ill take it off after my classes tomorrow and further inspect it. I managed to do the fuel pressure test today though and heres what I got:
This is with the vacuum line to the FPR disconnected and pinched
and this is when the vacuum line is hooked up to the FPR
Old 01-21-2016, 11:59 AM
took off the header and looked at it and the only thing I saw wrong,other than the header being old as dirt, is the broken bolt on the downpipe portion. Its been like this since I got the car could it just now be causing a problem even though its after the O2 sensor?
and heres a couple other pictures maybe you can spot something I missed.
Old 01-21-2016, 12:20 PM
Could a faulty MAP sensor be causing this problem without throwing a CEL?
Old 01-21-2016, 12:37 PM
The common crack area is in the exhaust manifold runner just behind the O2 sensor bung hole almost even with it.
If you're suspecting the MAP sensor I would advise you to replace the O ring under the MAP sensor. You can get one at ACE hardware that works (see pic) or get one at the Honda dealer part # 16075-P07-000, O ring (9.8x1.9)
Old 01-21-2016, 12:53 PM
Fish Twig
tony_2018's Avatar
Good ****, now if I could find a ACE hardware store around my area...
Old 01-21-2016, 01:02 PM
Theres plenty of ACE Hardwares in my area so ill stop by there and grab one of those and try that.
Old 01-27-2016, 11:06 AM
So I think I found out what has been causing my problems. I went to my friends house and put his P28 ECU in my car and the strong gas smell from the exhaust seemed to disappear. So today I opened up my ECU and in this area it looked problematic. Does anyone know if this could be causing my problem if its fixable?
Old 01-27-2016, 11:11 AM
Tegra206's Avatar
Ohh crap, I don't know about ecu's internals, But being that some kind of damage has occurred to the "brains" of your car, I would call someone immediately and see if a new ecu is needed. That doesn't look good to me, and it seems to be causing issues already that will probably keep getting worse.
GL bro
Old 01-27-2016, 11:37 AM
NotARaCist's Avatar
Just looks like normal surface corrosion to me If your friend's ECU fixed the problem, then investing in a replacement ECU wouldn't be a bad idea. I believe you can get it from Xenocron for a reasonable price.
Old 01-27-2016, 11:45 AM
I didn't have time to actually drive around with his ECU in, just put it in and wiffed the exhaust a little bit. I want to try and find a P28 to borrow for a day or 2 to test out before I drop $100-$190 on one. Unless someone has one they're trying to get rid off.
Old 01-27-2016, 01:40 PM
NotARaCist's Avatar
P28's are a seller's market - you aren't going to find someone "just trying to offload" one. If your friend can, see if he'll let you borrow his ECU for a week. Alternatively, hit up a pick a part yard, go scrounging around the yard for an ECU from a 92-95 EX, SI, or Del Sol SI. You should be able to get a P28 for cheap. Just bring a screw driver and open the case to make sure it hasn't been chipped. If it's cheap enough, don't even worry about 5MT vs 4AT - you can spend $30 on a diagnostic ECU.
Quick Reply: Car running rich, black smoke and soot from exhaust
