car pulls to the right
i just rotated my tires and now it pulls the right and it gets really annoying, if i rotate the just the front 2 tires will it even out? i had an alignment done a couple months be i rotated my tires
Re: car pulls to the right (egcoupe)
are they radial tires? You moved the front left to the rear left and front right to rear right correct?
You might need another alignment.
two things i can think of, not sure if any applies
difference in traction due to different types of tires
difference in circumfrence, but shouldn't be if you bought tires as a set
All Motor Mentor
1 Post
if your tires were worn improperly to begin with, as soon as you rotate them they will pull in the direction they were worn on. Your tires should "wear in" once they've been in the new location for a while and not pull as much. Changing the tires would be the ultimate answer, I doubt alignment is the problem since it didn't pull until after you rotated the tires.
Location: With my POS D15B2, Whereever whenever, United States
Re: car pulls to the right (00Red_SiR)
well if you were straight before, it means you need an alignment and also new tires
camber or toe is way off
Re: car pulls to the right (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">are they radial tires? You moved the front left to the rear left and front right to rear right correct?
You might need another alignment. </TD></TR></TABLE>
yep and i bought them as a set. i took it to wheel works to get it allinged cuz it was way off and when i got it back it felt exactly the same like the didnt even touch it so i took it back and it felt nearly perfect but when i rotated them it now pulls
Re: car pulls to the right (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">well if you were straight before, it means you need an alignment and also new tires
camber or toe is way off</TD></TR></TABLE>
my tires are almost new maybe a couple thousand miles on them
Re: (egcoupe)
get your alignment checked again. if the car pulls to one way, your tires soon will wear down to the metal within weeks. mine happened a few days ago.
All Motor Mentor
1 Post
Re: (egcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">but it wasnt like that before i rotated them</TD></TR></TABLE>
That's because when people lower their cars and don't keep them aligned properly they tend to wear on the insides of the tires which causes them to be prone to following the uneven road lines. The problem here is your tires and the way they were worn BEFORE you rotated them, not alignment. You have 3 choices: 1) replace them. 2) leave them and let them "wear in" in there new positions. It won't go away but should improve over time. 3) rotate them back to where they were and replace the tires as they wear out 2 at a time.
All Motor Mentor
1 Post
Re: (egcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">my car isnt lowerd though</TD></TR></TABLE>
A lowered car is the most common way for people to get abnormal tire wear...I was just using it as an example. In your case your abnormal tire wear was from poor alignment...either way the point I was making was that abnormal tire wear is what's responsible for your car pulling like it is. Another good point that was made is to check your tire pressures...good place to start!
