car pulls to the left..then to the right..
Old 03-04-2003, 08:09 AM
WongFeihung's Avatar
Default car pulls to the left..then to the right..
Well, I just got my si not to too long. Before I bought the car, the guy had it dropped 4 inches. I told him I'll buy it if he raises up to stock height. Apparently he told me he has done it..but I feel a pull to the left and to the right while I drive. Like the car will pull to the left hard...then to the right hard. All my wheels have no wear on them, all except the back right tire. The inside is all worn out. Now I have new tires and its weird how the back right tire is worn out on the inside. Can any of you help me on what is going on?
Old 03-04-2003, 08:16 AM
whoa its len 2's Avatar
Default Re: car pulls to the left..then to the right.. (WongFeihung)
Has the car been alligned after it was raised? Could be anything..
Old 03-04-2003, 08:17 AM
romeo619romeo's Avatar
Default Re: car pulls to the left..then to the right.. (whoaitslen2)
well he pput the front tires on the back ... and you sure need an alignment
Old 03-04-2003, 08:18 AM
no it hasnt..I might have to get it re aligned ..but the weird thing is..It didnt pull to the left or to the right until I got my 15 inch rims. Last week, I was rolling on 14 inch cheap font metal rims..and the ride was perfect. But when I put on the 15's ...it started doing this..
Old 03-04-2003, 08:21 AM
boostsohfast's Avatar
sometimes it might be the road you are driving on... I know on certain highways the groove that is made from big trucks pulls on my wheel in different directions. Does it happen all the time or only on certain roads?
Old 03-04-2003, 08:23 AM
Default Re: car pulls to the left..then to the right.. (boostsohfast)
yea, all the time..straight smooth road, with no cars i tested it..and bumpy roads as well.
Old 03-04-2003, 08:40 AM
Mojo-Jojo's Avatar
Probably a toe problem.
Make sure all the tires are pointing the right way if they're unidirectional because that's a free check you can do yourself, and then get an alignment.
Old 03-04-2003, 08:42 AM
Default Re: car pulls to the left..then to the right.. (Mojo-Jojo)
thx for the input guys.
Old 03-04-2003, 08:49 AM
B16A2-EM1's Avatar
Does it only happen when your shifting?
Old 03-04-2003, 09:38 AM
Chris(Youngstown)'s Avatar
Default Re: car pulls to the left..then to the right.. (B16A2-EM1)
Some things to check: 1. Any spring damage? If one of the springs is cracked/cracking, that'll cause some serious sway. 2. Bent 15 maybe? 3. Blown strut(s)... not likely if it does it on smooth roads too. 4. could be a camber thing. I'm sure there's lots more. Hope you get things straightened out.
Old 03-04-2003, 09:45 AM
deftones0817's Avatar
Default Re: car pulls to the left..then to the right.. (Chris(Youngstown))
might need to get rims balanced.
DEF
Old 03-04-2003, 09:53 AM
SOHC_MShue's Avatar
Default Re: car pulls to the left..then to the right.. (deftones0817)
i got an alignment once i got my 15's
Old 03-04-2003, 03:45 PM
no, it happens when it is is gear..anyhoo, thanks for the input guys. you guys never let me down.
Accord2009
09-06-2017 10:16 AM
meangreenEG
10-06-2009 07:45 PM
ten2doyle102
03-04-2009 07:44 PM
fubar
01-29-2006 05:34 PM
Quick Reply: car pulls to the left..then to the right..
