Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: How to replace thermostat
Step by step instructions for do-it-yourself repairs.
Car overheats.. new thermostat and radiator
93 honda civic.. I replaced the radiator a couple of months back and it has been fine until about a week ago when it overheated, thought it was just out of coolant so i filled it up and it was fine until last night when the same thing happened and coolant was spraying out of the overflow tank, then i noticed the bottom hose was cool so i thought maybe it was the thermostat... replaced that today and it just overheated, still spraying coolant everywhere on my way home.. only other thing i can think of is something with the fan? Does anyone have any ideas or suggestions?
be professional
Re: Car overheats.. new thermostat and radiator
If it's a D15B7, the head gasket is probably blown.
Where did you get the thermostat and what brand is it?
Temp sensor. should be right next to the thermostat in the housing. If the radiator and thermostat are fine, that has to be the issue. The fan may not be kicking on, but that usually makes you run warmer than usual, not THAT hot.
Looks like this:
Looks like this:
be professional
Just went and looked at the box, the brand was Valucraft, and i remember noticing the one i took out looked bigger.. that could be causing it too over heat and spray coolant?
be professional
If a Honda thermostat doesn't solve the problem, your head gasket is bad.
or possibly
you have problem with the fan not kicking on, this would over heat at idle but would go back to normal when your at cruising speeds
some things i would suggest doing is bench testing the thermostat (boiling water pot and kitchen thermometer, and checking if its properly installed. maybe try pulling one of your hoses and starting the car, let it drain into a bucket, and clarify good flow
Alright, I will go down to the Honda dealer tomorrow and see if they have them. Hopefully that's all it is. Thanks for the help!
your at two possibilities here:something is blocking coolant flow dramatically, a cloged radiator or bad or improperly installed thermostat are the most common (you and already replaced the rad)
or possibly
or possibly
Replaced the Autozone thermostat with the Honda thermostat and took it for a drive and i haven't had any problems so far! Thanks for the advice!
be professional
if you kept the box for your autozone part then go return it as defective. bring your honda receipt and let them know their part was trash. just like everything else in their store.
Seagull Management
Because that's a great way to ensure you'll always pay retail from there on it. Most parts store parts are crap, it is what it is. But if you buy any amount of stuff they'll usually give you a pretty decent discount once you've been coming in for a while. There are times when you will need to go in there again. For the $10 - $15 or so a thermostat costs from a parts store i'd probably just keep my mouth shut and write it off as a loss.
EGcivic_95
31
01-29-2011 06:09 PM
PearlWhiteAccord
09-25-2002 12:15 PM
autozone, car, civic, coolant, fan, honda, improperly, installed, overheats, price, radiator, retail, sprays, stant, thermastat, thermostat, thermostats, work
