Car overheating due to A/C?
Old 09-02-2005, 04:20 PM
zerovandez's Avatar
Default Car overheating due to A/C?
Ok, my bro has a 1997 honda civic DX coupe. He says when he turns on the A/C his temp meter rises. Turns it off and it slowley comes back down. What can be causing this?
Old 09-05-2005, 04:44 PM
zerovandez's Avatar
Default Re: Car overheating due to A/C? (zerovandez)
anyone?
Old 09-05-2005, 05:43 PM
sam385's Avatar
you may over-heat because the A/C condenser cooling fan is not operating
Old 09-07-2005, 08:39 AM
zerovandez's Avatar
can anything else cause this?
Old 09-07-2005, 10:38 AM
jdmgoldcivic's Avatar
Default Re: (zerovandez)
When I used to have A/C in my 1993 civic coupe it would do that and it was because the coolant needed changed. It was very brown when i got it changed and never had a problem after that
Old 09-08-2005, 02:15 PM
LatinEM2's Avatar
i have a similar problem..my temperature needle goes up when im at a stop light or at idle..but once i get going it begins to drop down to normal temperatures..i replaced the coolant and thermostat already..and that didnt' fix it..any other ideas??
Old 09-08-2005, 02:47 PM
zerovandez's Avatar
thanks guys! I'll check these out.
To latinEM1, it sounds like your fan isn't running. When your stoped, there is no air flowing through the radiator, when you move there is. This would cause your radiator to cool a bit I'd imagine. I'd leave my car in idle, pop the hood and rev the engine a bit just to get it to normal temps and check to see if the fan turns on. If not, replace the temp sensor first (don't know tech terms), if that doesn't help...check fuses, etc...Worse case, change the fan. If none of this helps. Then I don't know
Old 09-08-2005, 02:53 PM
LatinEM2's Avatar
Ok, thanks..but i do feel and i have seen my fan turn on..
Old 09-10-2005, 11:16 AM
latindc2's Avatar
ok turns out...my A/C is turning on..and my rad fan is not..when i unpluged the radiator conector nothing happened..but when i repluged it back in..the fan turned on!...so what could cause this?? help..
EDIT:...whoops. this is LatinEM1..i forgot i was under my bro's usename..lol..
Old 09-10-2005, 04:45 PM
SiR:Mallard's Avatar
Bump for the fan not coming on.
Old 09-10-2005, 04:56 PM
ROK801's Avatar
Default Re: (latindc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by latindc2 &raquo;</TD></TR><TR><TD CLASS="quote">ok turns out...my A/C is turning on..and my rad fan is not..when i unpluged the radiator conector nothing happened..but when i repluged it back in..the fan turned on!...so what could cause this?? help..
EDIT:...whoops. this is LatinEM1..i forgot i was under my bro's usename..lol.. </TD></TR></TABLE>
bad connection...
the plug might have come loose.
if it stops working again, you could have a short somewhere in the wiring.
JacobAF20
Honda Civic (2001 - 2005)
09-24-2016 10:51 AM
EGcivic_95
31
01-29-2011 06:09 PM
edwinbaby
12
06-14-2010 09:19 AM
jdmCivic925
12
06-18-2006 04:58 AM
purple98ek
06-26-2005 04:38 PM
Quick Reply: Car overheating due to A/C?
