Car Occasionally Won't Start, no check engine light. - Honda-Tech
Old 08-10-2011, 07:31 AM   #1
Icon3 Car Occasionally Won't Start, no check engine light.
Intro:I have a 1993 Honda Del Sol with a 1997 Acura Integra GS-R swapped in. My problem with getting my car to turn on began on 08/08/11. The car has not had any problems and was running amazingly. There is no engine light going on. This car was sitting for about Six months without any real driving. But I recently did a engine and transmission oil and change. New spark plugs, and I will be changing the spark plug wires, distributor cap and rotor, and fuel filter soon.
Diagnosis: I turned the key and listen for the fuel pump to prime. If it doesn't prime the car cranks but wont turn on. If I wait about 30 minutes or so and I try again the car sometimes obeys and comes to life. After trying the first time and the car doesn't start any attempts after just cause the engine to turn over more but it still doesn't start.
Questions:1) Is this a sign my fuel pump is going out?
2) If my fuel pump is going out can I replace it with a walbro 255 and be good to go with a stock fuel filter, fuel rail, and injectors?
3) Would a fuel filter cause my car to not start?
Benito89 is offline   Reply With Quote
Old 08-10-2011, 07:38 AM   #2
Default Re: Car Occasionally Won't Start, no check engine light.
Former User is offline   Reply With Quote
Old 08-10-2011, 07:45 AM   #3
20% cooler
thenext's Avatar
I been wondering about that myself. Are those relays much to replace if somethin gets fawked up soldering it?
thenext is offline   Reply With Quote
Old 08-10-2011, 07:47 AM   #4
Wow sounds like you just solved my problem Thank you, Would I be able to just replace the main relay? I don't trust my soldering lol. I'm now looking on rockauto.com, does the main relay go by another term?
Old 08-10-2011, 08:36 AM   #5
You can buy new main relay, if you wish. I always post the resoldering fix as it's the cheapest road to solve the issue.
Old 08-10-2011, 11:17 AM   #6
20% cooler
thenext's Avatar
The main relay costs anywhere from $40-$60. I just pulled mine out today and re-soldered the posts. It is really super easy man! Even if you suck at soldering.
http://www.marklamond.co.uk/tech-hon...main-relay.htm
This link tells you the EXACT posts that go wrong too.
Old 08-10-2011, 02:00 PM   #7
definitley main relay had same problem get it new from dealer its about $80 no spark no fuel just doesnt turn over definitly main relay
kingjames0509 is offline   Reply With Quote
Old 08-10-2011, 03:43 PM   #8
Quote:
Sweet, do you know where else I can pick up a main relay? I found one a site that was 60 bucks but lost the link.
Old 08-10-2011, 03:45 PM   #9
Quote:
the following link is the website i found that has a few relays im kinda confused over the whole 7 pin mitsuba rz-0132 and the RX-0159... last bit of help please and thank you?
http://www.overnightautoparts.com/st...t=main%20relay
Old 08-11-2011, 07:40 AM   #10
xero_xero's Avatar
as far as the main relay, what all does it control? just efi function? start? fuel pump?
xero_xero is offline   Reply With Quote
Old 08-11-2011, 07:55 AM   #11
^All of the above.
As far as buying one, most local parts stores carry them.
StreetsideStig is offline   Reply With Quote
Old 08-11-2011, 07:31 PM   #12
xero_xero's Avatar
starter has no relation to this main relay.
Old 08-12-2011, 06:14 AM   #13
Huh. I thought it did. My bad.
No fuel car won't start Jose A Aispuro Honda Civic / Del Sol (1992 - 2000) 6 01-06-2017 06:18 PM
Fuel prime problem 808civi Honda Civic / Del Sol (1992 - 2000) 19 05-29-2016 06:42 PM
92 Del Sol - Non Starter - has spark and pump primes asletclark Honda Civic / Del Sol (1992 - 2000) 16 09-05-2012 05:21 AM
Number 2 Cylinder Misfire? what are the causes? and fuel pump problem 92integraVTECgsr Acura Integra 6 02-19-2006 11:45 AM
calling all b16a gurus mrduque Hybrid / Engine Swaps 5 06-20-2002 06:05 PM
Tags
1993, car, check, civic, engine, honda, light, occassionally, on, relay, service, start, time, won, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
