piston ring gap???
Old 08-09-2011, 06:54 PM
bradabu's Avatar
Default piston ring gap???
im installing arias 11:1 forged pistons into my b16. stock bore 81mm and im wanting to know what to get the rings to? 1st and 2nd?
thanks
Old 08-10-2011, 05:40 AM
bigwheel1983's Avatar
Default Re: piston ring gap???
could you not contact the manufacturer?
Old 08-10-2011, 10:26 AM
PhillyDelSol's Avatar
The measurements should be in the package with the rings. If not do what bigwheel says and contact manufacturer.
Old 08-10-2011, 11:01 AM
the rings might even be pre-gapped!
have you measured them yet?
Old 08-11-2011, 04:52 PM
bradabu's Avatar
i called the manufacturer and they said there not pre-gapped
Old 08-12-2011, 05:18 AM
bandit67's Avatar
Very open ending question. You want the gap a small as possible without the ends EVER touching. This is where the maker comes in. What type of material are they made of, what is the application. Boosted creates more heat, as does nitrous, more gap. Hi compression can mean more heat.....track car or street. At the very least a machine shop that bores, builds, supplies kits should be able to supply the manufactures guidelines if no paperwork on pistons can be acquired.
ZCHondaCRX91
Engine Machining & Assembly
02-12-2019 02:43 AM
MastaFlyMason
12-14-2017 04:08 PM
JJDub
05-31-2017 07:30 AM
siis2fast
06-07-2005 03:52 AM
B19CivicHB
06-19-2003 04:15 PM
Quick Reply: piston ring gap???
