Car not starting. Clutch switch or starter? Help - Honda-Tech
Old 03-31-2011, 10:08 PM   #1
zerovandez's Avatar
Default Car not starting. Clutch switch or starter? Help
1997 Civic Hatch with B18C GSR engine. Runs fine and is BAR'd in Socal. Something strange has been happening recently, but not often. The car doesnt start all of the time. I press the clutch, turn the key, then nothing. I don't even hear the starter cranking. Everything else seems to go like the humming of the fuel pump, dash lights, and stereo. Doesn't seem like an electrical problem. I'm thinking a bad clutch switch, or starter. What do you think?
zerovandez is offline   Reply With Quote
Old 03-31-2011, 10:09 PM   #2
Default Re: Car not starting. Clutch switch or starter? Help
Start by check whether the rubber stopper that presses on the switch is damaged.
Former User is offline   Reply With Quote
Old 03-31-2011, 11:19 PM   #3
mooze's Avatar
had this issue to...it eventaully just stopped all together..i just bypassed the clutch switch
mooze is offline   Reply With Quote
Old 04-01-2011, 06:42 AM   #4
zerovandez's Avatar
Thanks guys. I'll have a look this weekend. Is there a reason for 2 clutch switches? To bypass, just jump the 2 wires leading to the switch, right?
Old 04-01-2011, 06:47 AM   #5
The upper switch is for the starter and the lower one is for cruise control.
Don't permanently jump the starter switch connector. It's unsafe. Start by checking the rubber stopper and whether it is adjusted properly for the pedal height.
When you turn the key to ON(III) to start the engine and it doesn't crank, do you still hear the starter solenoid click? If so, your starter may be on the way out.
Old 04-01-2011, 01:43 PM   #6
zerovandez's Avatar
No. I don't hear the starter solenoid click. Completely silent with the excpetion of the fuel pump. I guess I wouldn't have to worry about the CC switch. The ECU is putting out P1456 and P1457. I wouldn't think this would have to do with anything I'm experiencing, right?
Old 04-01-2011, 02:05 PM   #7
CAVTECSol's Avatar
It could be your coil. I had mine go out around 120k and it had the same symptoms you're seeing.
CAVTECSol is offline   Reply With Quote
1996 Honda Civic - cranking Issues Leon999 Honda Civic / Del Sol (1992 - 2000) 40 02-06-2015 02:27 AM
95 civic wont start DeeJHonda95 Tech / Misc 5 01-27-2014 08:16 AM
help! J3450 Honda Prelude 11 03-18-2012 10:43 PM
Help with something strange... zerovandez Honda Civic / Del Sol (1992 - 2000) 1 03-31-2011 09:58 PM
89 SRX won't start wood Honda CRX / EF Civic (1988 - 1991) 8 08-16-2005 08:09 PM
Tags
1997, 97, bad, car, civic, clutch, cluth, failing, helps, honda, rubber, start, starter, stopper, switch, tech, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
