car kind of feels like it's jerking on highway driving - Honda-Tech
Old 08-19-2009, 11:23 PM   #1
mynameizstitch's Avatar
Default car kind of feels like it's jerking on highway driving
ok got a b16a3 with itr cams, dc header, aem cai just tuned on crome with a p28 ecu. when i drive on the freeway sometimes i feel like the car is jerking a little. it's not a lot at all but it's enough to just notice it. with my stock ecu everything runs fine and smooth. after the tune is when it now sometimes feels a lil wierd (hard to explain) but all i know is that it feels kind of like a "jerk" on the car when accelerating at a steady speed. i will check my spark plugs soon to see if they are fouled out since it seems like the car is running a lil rich after the tune.
***car is not throwing any engine check light codes and stuff like that. to me it seems like the car is running a lil rich.
mynameizstitch is offline   Reply With Quote
Old 08-20-2009, 12:37 AM   #2
Sleeperzzz95's Avatar
Default Re: car kind of feels like it's jerking on highway driving
Tire may need air/too much air. Alignment. Wheel balanced. Camber. I dont think the motor or tune has to do with anything with your car jerking. But i could be wrong lol
Sleeperzzz95 is offline   Reply With Quote
Old 08-20-2009, 02:48 AM   #3
.hawaii's Avatar
alot of the times its the simplest thing. check your throttle cable/cable bracket to see if its stuck. :p
.hawaii is offline   Reply With Quote
Old 08-20-2009, 02:58 AM   #4
92slowcivic's Avatar
Quote:
i *think* he means the engine is not pulling smoothly, not that the car jerking from one side to another (such as needing an alignment.) then again, i could be wrong.
92slowcivic is offline   Reply With Quote
Old 08-20-2009, 06:50 AM   #5
Crossbreeder's Avatar
Im taking it as suspension issue. SHake your front end down.. If you know what I mean. You could need a wheel bearing.. inner and or outer tir rod. It could be a bumber of things. But im not taking it as a motor issue.
Crossbreeder is offline   Reply With Quote
Old 08-20-2009, 07:18 AM   #6
andoxviii's Avatar
A bad TPS will cause the car to jerk a little bit on constant throttle...I'm having this issue right now with my Y7.
andoxviii is offline   Reply With Quote
Old 08-20-2009, 08:30 AM   #7
car just got an alignment 3 months ago. i will check my tire pressure.
Old 08-20-2009, 09:36 AM   #8
Gunmetal_B20_Hatch's Avatar
get a wideband & verify AFRs
Gunmetal_B20_Hatch is offline   Reply With Quote
Old 08-20-2009, 09:44 AM   #9
Hmmm after i reread your post..Now it sounds Like the Car is hesitant. Buckin so to speak. What gas is your car tuned on an what gas do you have in car? Bad gas mixure?
Old 08-20-2009, 05:14 PM   #10
always using 91 octane gas and im pretty sure it was tuned on that since cali dont have anything higher.
Old 08-20-2009, 05:15 PM   #11
Quote:
here is my graph of the dyno tune bottom parts read air fuel which i dont know howt o read it haha
Old 08-20-2009, 06:28 PM   #12
would need to know AFRs @ cruising speed.
Old 08-20-2009, 07:13 PM   #13
Quote:
Im also having the same problem..
Christopherian1982 is offline   Reply With Quote
Old 08-20-2009, 09:23 PM   #14
Thizzed Out's Avatar
I'm also having this problem, it seems like the engine is jerking a tiny bit just enough to notice. How would I go about testing the TPS?
Thizzed Out is offline   Reply With Quote
Old 08-23-2009, 05:29 AM   #15
so you're saying it's the engine not pulling smoothly and not a suspension or alignment issue? there still seems to be some confusion.
i had a problem with my tps on my gsr swap a couple times and i didn't even need to replace it, it just needed to be cleaned.
Old 08-27-2009, 07:16 PM   #16
How do you clean it where do you spray and what do you use to clean it with?
Motor jerks intermittently when idling jdm91integ Honda Accord (1990 - 2002) 16 06-27-2014 04:00 PM
Car jerking at low RPM why??? mynameizstitch Honda CRX / EF Civic (1988 - 1991) 4 02-21-2012 01:41 PM
Car jerks when rolling slow 91b18a1ls Acura Integra 24 02-21-2011 03:27 PM
help...wheel jerking to the right. nautica_t Acura Integra Type-R 12 10-25-2006 07:28 PM
Car Bogs/Jerks Randomly at partial throttle: p28 + Hondata... TPS issue? turbotime Forced Induction 9 10-24-2005 10:11 AM
Tags
1992, accord, bad, car, cars, drive, driving, engine, honda, jerk, jerking, jerks, reasons, road, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
