Car idling funny, jerking hard when changing gears\letting off throttle :( d16y8
Old 09-01-2006, 04:38 PM
EJ8beast's Avatar
Default Car idling funny, jerking hard when changing gears\letting off throttle :( d16y8
For about a month now my car has been idling real high.. its not every day but it has.. usually jumping from 1,500 and going down to 800..
Today though when I was driving to work it was acting extremely strange.. it sat at 1,500 at idle and would jerk real violent when I would change gears and release the throttle.. when i would step on it a little it would also jerk..
on first gear when i hold the throttle lightly it jerks constantly.. and begins to idle funny like if it has a cam or something
sorta like.. woom mm woom mm woomm woom mm, :X
I had thought originally it was the IACV but it just feels like a piston aint working or something, anybody ever come across this prob? what could it be ><!!
The jerking feels like your car would feel when you would downshift.. except its all on the same gear (or gears, does it 1,2,3,4 and 5 gear)
EJ8beast is offline
Old 09-01-2006, 04:42 PM
SicilianSpeed42's Avatar
Default Re: Car idling funny, jerking hard when changing gears\letting off throttle :( d16y8 (EJ8beast)
a vacuum leak might be causing that idle problem, spray some carb cleaner on all the vacuum lines and see if the car wants to die, if it does you know you have a leak
SicilianSpeed42 is offline
Old 09-01-2006, 04:55 PM
EJ8beast's Avatar
Default Re: Car idling funny, jerking hard when changing gears\letting off throttle :( d16y8 (SicilianSpeed4
so I spray it OVER the vacuum lines? k, i'll try that
anybody else have any other suggestions?
EJ8beast is offline
Old 09-01-2006, 05:32 PM
yup... on, over and around the vacuum lines. If there a leak it will suck up the mist and cause the engine to stumble, almost stall.
Old 09-01-2006, 06:32 PM
NathanielH's Avatar
disconnect thie IACV when the idle starts to bounce, and see if it stops
NathanielH is offline
Old 09-01-2006, 06:39 PM
xNOBOOSTx's Avatar
Are you throwing any codes? This happened to me but it was from where i removed my cruise control and didnt plug the vacuum port on the intake manifold. More than likely a vacuum leak causing your problems.
xNOBOOSTx is offline
Old 09-01-2006, 06:59 PM
Jay_Sensing's Avatar
Ditto, just fixed a friends car with the exact same issues. He has a torn Tbody gasket from his AEBS install. Car was horrible. New gasket and a little sealant, car runs like a top.
Jay_Sensing is offline
Old 09-01-2006, 11:46 PM
si_kitty's Avatar
Default Re: (Jay_Sensing)
my car does this too but not all the time.
some times it idles ok (always higher than my bf's) and drives wonderful. other times it idles high and if you ease the clutch out at low speed and try to drive with level gas pedal it jerks like a bucking horse. then the throttle is like an on/off switch... nothing is smooth.
I hate it, and the bf doesn't know what to do.
help me!
si_kitty is offline
Old 09-02-2006, 05:35 AM
EJ8beast's Avatar
Default Re: (si_kitty)
thats the same problem im having!! Its not all the time..
But when it happens its horrible. like it wants to pull your rev down.
FOR EXAMPLE. it will be idling at 1600 rpm idle.. rev it up a little to lets say 2500 and it shoots RIGHT BACK down to 1600, sorta like a motorcycle.
EJ8beast is offline
Old 09-02-2006, 04:26 PM
si_kitty's Avatar
Default Re: (EJ8beast)
... or sitting at idle and barely put foot on gas, and rpm jump up and down and up and down making whole car shake.
hate that!
someone help me get this to stopppp.
si_kitty is offline
Old 09-02-2006, 06:06 PM
that might be a tps problem, vacuum leak would make your idle surge and go higher
Old 09-02-2006, 08:23 PM
xNOBOOSTx's Avatar
Well we cant help if you dont tell us what youve tried. Have you checked all the vacuum lines and ports, have you checked the IACV? Have you recently done anything to your car that might make it do this. Talk to us man.
Old 09-02-2006, 10:52 PM
CantThinkOfAScreenName's Avatar
Default Re: (xNOBOOSTx)
Why dont you check the Fast Idle Thermal Valve, if that plungers not screwed in all the way itll cause an irratic idle. Also low coolant will cause an irratic idle also.
CantThinkOfAScreenName is offline
Old 09-03-2006, 12:18 AM
si_kitty's Avatar
Default Re: (CantThinkOfAScreenName)
the guy that put the b20 in the bf's car checked the iacv thingy. mine is fine. I am gonna make him look at all my vacuum lines now. hope that is it. this is driving me krazy.
si_kitty is offline
Old 09-03-2006, 06:57 AM
CooBlueDAB's Avatar
lol, so you mean... (im such a manual car noob) that in the lower gears, 2nd, and 1st... on occassion 3rd... that if I let off the peddle, it should not suddenly slowdown or at lower RPS kind of lurch gerk as the rpms drop?
Just had a tranny rebuilt for too much... shifter was tightened and feels notchy but if I have another problem im going to flip.... I don't have anymore money lol
CooBlueDAB is offline
Old 09-03-2006, 07:13 AM
EJ8beast's Avatar
I havnt done anything to the car except I\H\E.
I cleaned out the IACV with some brake cleaner and still same prob.
I am going to look into bleeding my coolant today.
Last night it happened again.. just for kicks i dropped to 3rd gear and let the rpm's fall.. as soon as it reached 2000 rpm it started jerking really violently like if it wanted to shut off..
EJ8beast is offline
Old 11-28-2006, 05:42 AM
95TEG's Avatar
Any remedies on this yet?
95TEG is offline
Old 11-28-2006, 05:49 AM
EJ8beast's Avatar
Default Re: (95TEG)
i ended up adjusting the idle and it went away.
EJ8beast is offline
Old 11-28-2006, 06:01 AM
Dwight Schrute's Avatar
having the same jerking problem. disabled my fitv, bled coolant 900 million times, cleaned iacv, new o2, new fuel filter, new plugs, new oem wires, newer cap and rotor. im about to replace the tb gasket as well.
Dwight Schrute is offline
Old 06-05-2011, 02:44 PM
Former User's Avatar
Old thread closed.
Former User is offline
DuecedSol
Honda Civic (2006 - 2015)
10
08-08-2014 07:26 PM
stivic
11-28-2007 02:58 PM
NikoZai
03-18-2006 04:59 PM
Quick Reply: Car idling funny, jerking hard when changing gears\letting off throttle :( d16y8
