car swerves at high rpms????
Old 09-22-2009, 09:45 PM
leroy12's Avatar
Default car swerves at high rpms????
Ok, looking for some much needed help.
The car
93 hatchback SI
ls/vtec turbo
The problem
At high RPMs when i shift the car literally jerks to the left or right(depends on what it wants to do at the time, cause its random)
it doesn't only do it when i shift cause it also does it when i just speed up into higher rpms.. it jerks enough to cause the car to swerve into another lane...
it doesnt do it at low rpms.
I replaced
axles
skunk 2 chamber kit(new ball joints)
right side wheel bearing
Most front suspension bushings.
my steering wheel is kinda crooked when the wheels are staight
i was told i need new tie rod ends by a mechanic. also told i need a new rack and pinion.
What could it be?????? any ideas???? Advice much appreciated!!!
Old 09-22-2009, 10:27 PM
crxboy909's Avatar
Default Re: car swerves at high rpms????
just go by what the shop says.... and get an alignment
Old 09-22-2009, 11:50 PM
ddd4114's Avatar
Are you sure you're not just losing traction?
Old 09-23-2009, 03:12 AM
New User
xanctuary's Avatar
Hey, I got a similar problem. I believe it's because inner/outer tie rods being a bit loose.
Try lifting the front of you car, so both tires are off the ground, and wiggle your rims to see if they move
(turn your wheel so it's locked). I don't think your rack & pinion needs replacing tho... but like crxboy says,
you should do what the shop says & get an alignment.
check other shops too.
Old 09-23-2009, 03:23 AM
hondamark35's Avatar
ignoring what the mechanic told you, if you take it for an alignment, they won't be able to do it if the tie-rod ends are worn. like xanctuary said, check them out yourself. it's not hard to replace the outer tie-rod ends yourself, and it's much cheaper. then get it aligned.
(also with an LS turbo you're probably getting a lot of torque steer at high rpm which initiates the jerking. but because of your tie-rod issues and maybe need for an alignment, you aren't able to safely control it. just my theory..)
Old 09-23-2009, 03:30 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Exactly what I was thinking. Tie rod ends + torque steer. Any light fwd over 200HP is going to torque steer to begin with. Worn steering components will make it dramatically worse.
Old 09-23-2009, 10:42 AM
New User
xanctuary's Avatar
BTW, the passenger side inner tie rod was the problem with my car. You can buy tie rod removal tool for around $30 + $60 for set of inner/outer tie rod. Dont forget to change the boots as well while your at it.
Old 09-23-2009, 12:47 PM
right. you can also avoid the $30 for the tool if you're handy with a ball-pien.
Old 09-23-2009, 01:46 PM
Former User's Avatar
Are your motor mounts shot?
Old 09-23-2009, 02:07 PM
Corksil's Avatar
my car does this too, I would say it's partially tierod ends (I hit a rock hard enough to dent my rim and this bent the tie rod) and partially torque steer.
meaning one wheel starts spinning and looses traction, then the other wheel has traction and the car gets yanked to that side... kind of dangerous on the street, and worse on wet roads.
NUMISMATICS
31
06-20-2012 12:41 AM
j0keefe21
02-05-2009 04:25 PM
y7turbo
Suspension & Brakes
01-22-2009 08:45 PM
brookliner7
03-17-2005 06:59 AM
iNetForce
07-19-2004 01:31 PM
Quick Reply: car swerves at high rpms????
