car dies when i give it gas..HELP
94 EG
B16a2
NO CELs
Swapped in b16. cranked her up and she idles perfectly, but when i give it gas i she revs to 2-3k and dies out. The dizzy is brand new so are the plugs. As soon as i tap the gas she starts boggin and if i keep my foot on the gas she dies out completely. Timing is on. anyone out there have this problem before?
B16a2
NO CELs
Re: car dies when i give it gas..HELP (racerxh00)
alrightty im going to check for leaks right now..i did that already but i will double check
Re: car dies when i give it gas..HELP (MI4$DC5)
just checked for leaks and i have no leaks...i even tried swapping the MAP and TPS but that didnt work either. Could it my fuel pump. i mean the car starts and idles fine, its just when i give it gas it dies out like its not getting any fuel
If your sure the timing is right, then check the fuel filter as mentioned above. A lot of the time that is the problem, its lets enough flow for a idle but is so clogged it can supply enough fuel above idle.
Re: (MI4$DC5)
dam TPS is good...man im freaking stumped like a ****...i guess my next move would be to get another fuel pump?
Re: (MI4$DC5)
check for cracks in the air intake. (pgi-fi?) also. you may have a clogged injector, or ones not working. what do you mean it dies? when you punch it and let off does it go back to idle? if its that check you dizzy timing!
Re: (One Day H23)
no i mean, when i cut the car on it starts up and idles fine. But when i give it gas once it hits around 2500-3k rpms if i leave my foot on the gas it cuts off, but if i let off while its bogging and choking then she goes back to idle. She idles all day.
my d15b swap on my 4door usto do that Until i open the throttle body more to breath more air its a flat screwdriver and give it more air man it needs to breath! you will see it right on the air throttle body man :-) 4 reals!
Re: (MI4$DC5)
Sounds like im having almost the exact same problem Only difference may be That sometimes I can pump the gas pedal and it starts taking gas but something aint right. Please let me know if and when you figure it out. I will do the same if I figure it out. Oh by the way, a mechanic said it sounded like a weak fuel pump but I havnt followed up on it and tested it yet. Later
Re: (T_Blaze)
if he had a clogged cat, the car wouldnt have no power. im thinking theres a vaccum line in the wrong spot, or off. Fuel injectors would do that also. but if it were FI's then it would run rough idling also. worth a try taking the manifold off.
