Car Died While Driving! Help ASAP!
So today I was leaving work and going to class when my car was studdering/hesitating. Then all the sudden it starts cutting out real bad and eventually dies all together. I pull to the side of the road and try to restart my car but it wont start again. Long story short got towed home and been working on it ever since. So far I've checked the following:
Alternator - Took off and tested at AutoZone, its Good
Fuel - Checked to see if fuel was entering the cylinder head, it has fuel so check!
Spark - Now here is the problem, I took my spark plug out with it still connected to the spark wire, I had my g/f crank the car while i watched for a spark. It DID NOT spark, so I checked #2 and the same thing.
My question is what could be causing it to not get spark? I was thinking distributor since its not getting any spark. Recently the coil inside the cap was kinda bent so I attempted to bend it back into place (Its a MSD cap/wires). Also it acts like it wants to crank over but it just doesnt have any spark to ignite the fuel.
Re: Car Died While Driving! Help ASAP!
likely problems in order of cheapest to most painful:
cap/rotor
coil
ignitor
being that something was kinda bent, and you attempted to bend it back. it probably attempted to bend back to normal and kinda broke.
cap/rotor
coil
ignitor
Thats what I was thinking, Im just trying to narrow it down.Thanks for the reply! Anymore input would be apprechiated.
How expensive are we talking? I'm pretty sure it's the dizzy. When I checked the plugs I grounded them to some metal on the engine and no spark came out regardless of which one. Like I said I'm POSITIVE its getting fuel the odor is more than would be in there without.
I bought mine from Partsource for $150 (CAD), and thats just your typical replacement one. If you want OEM Honda I believe it closer to $300.
Things to check,
cap/rotor
coil
ignitor
Obviously the ignitor will be last,EDIT: I check the fuses under the hood and inside the cabin and all the 15amp ones are good to go, so I dont think its a fuse problem. Hopefully I can get this figured out, getting a ride to school at 6 a.m is kind of hard.
Jason kiDD
03-19-2003 07:54 AM
