car died on me this morning. what could be wrong?
Old 05-08-2003, 05:24 AM
93civdx's Avatar
Default car died on me this morning. what could be wrong?
alright i was driving to school this morning and all of a sudden my car cut off and it wont cut back on. it will turn over but will not crank. on the inside my oil pressure light and my battery light are on. i have a 93 sedan with the d15b7 with a little over 128k on it. it has an aem cai, dc 4-1, obx muffler, alpine type r 12 with a mrd m300 amp. i was told that it could be the timming belt but it was replaced less than a year ago. i know that it it still could go wrong but i havent had time to look at it because i had to go to school. thanks for any help.
Old 05-08-2003, 07:36 AM
SloCivicHMM's Avatar
Default Re: car died on me this morning. what could be wrong? (93civdx)
Are ya getting spart?? could be your dizzy???
Check your oil like he said......check your coolant...look for an leaks around the head or block........if your oil is low look for a hole in the block!!
Old 05-08-2003, 08:03 AM
pennies_hatchie's Avatar
if its not cranking, then it might be your starter, also check your battery, thats probably why the battery light is on.
Old 05-08-2003, 08:52 AM
all stock's Avatar
Default Re: car died on me this morning. what could be wrong? (pennies_hatchie)
it might just be on because your car died. i don't thi nk it's your oil.
Old 05-08-2003, 08:57 AM
Solbros Owns Me
Evs-One's Avatar
Default Re: car died on me this morning. what could be wrong? (all stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">it might just be on because your car died. i don't thi nk it's your oil.</TD></TR></TABLE>
that is correct sir. Anytime your ignition is "on" and your car isn;'t running, you have no oil pressure-hence the oil light since your car's not running.
Did it just die???? Or did it make some noises then die????
I would check fuses first, make sure you have gas in the tank, getting fuel(turn ignition on and listen for fuel pump), and see if you're getting spark.
Old 05-08-2003, 09:11 AM
beseman's Avatar
Default Re: car died on me this morning. what could be wrong? (Emerika)
could be distributor, happend to mine once
Old 05-08-2003, 12:56 PM
93civdx's Avatar
Default Re: car died on me this morning. what could be wrong? (beseman)
thanks. yeah it just died. no funny noises or anything. i am begining to think that it is my dizzy. everything else seems to work. all the electrical and it had plenty of gas and the oil looked good. thanks for the help.
globy123
12-13-2010 10:30 AM
solidsnakex37
04-19-2008 11:45 AM
Cambo88zc
02-08-2006 05:04 PM
ncskate
06-02-2005 04:03 PM
PatrickGSR94
12-19-2004 07:02 PM
Quick Reply: car died on me this morning. what could be wrong?
