Car battery keeps dying - Honda-Tech
Old 10-20-2011, 09:15 PM   #1
Default Car battery keeps dying
Hey H-t, my car battery keeps dying. Idk what the problem is. My car is a 97 civic hatch dx. I left it in the garage for 2 weeks without driving it but a week ago I turned on the car and it was fine. Then I went to turn it on today and battery died. I then jumped it and it was fine. Left it on for about 20 minutes. I did drive it around. But then when I turned off the engine and try turning it back on battery died and I sopped touching it and now posting this. Anyone know what the problem is? Am I not leaving the car on(after jumping) long enough? Is it the alternator? or Starter? or Battery. HELP WOULD BE APPRECIATED!
Touek is offline   Reply With Quote
Old 10-20-2011, 09:21 PM   #2
piggy96's Avatar
Default Re: Car battery keeps dying
alternator or battery. most likely battery isn't holding a charge considering the car stays running after it's boosted
piggy96 is offline   Reply With Quote
Old 10-20-2011, 09:32 PM   #3
low91rex's Avatar
An easy way to check if your alternator is putting out you can use a voltmeter to test the battery while the car is running. If its working properly it should be putting out a voltage anywhere from 13-14 volts. Chances are your battery isnt taking a charge because its bad. you can take it to your local parts retailer and they will check how many cranking amps it has to determine if you need a new battery or not.
low91rex is offline   Reply With Quote
Old 10-21-2011, 04:20 AM   #4
angrysmileyface's Avatar
Its most likely your battery has met the end of its life. I had one where it was about 4.5 years old and it had just barely enough juice to roll the engine once, so I had to constantly use the booster box I had in the garage. Even had the parts store charge it to no avail. Best bet is to get it tested at the parts store, and buy a new one if it fails. If the battery checks out good, then I would begin looking for some sort of parasitic drain or a short somewhere.
angrysmileyface is offline   Reply With Quote
Honda Civic Lx 1998 Battery problems nicole berry Tech / Misc 1 12-14-2015 10:47 AM
2005 CRV and the battery keeps dying mydogFahey Honda Element & CR-V 10 03-29-2015 10:59 AM
car wont start 90ef hatch jdm.swift Honda CRX / EF Civic (1988 - 1991) 8 08-15-2010 08:54 AM
My abused but still bad-ass Honda Battery teal_dx Honda Civic / Del Sol (1992 - 2000) 1 08-14-2003 10:38 AM
battery problem, suggestions? bluesaint Acura Integra Type-R 4 03-06-2003 10:38 AM
Tags
91, acura, back, battery, car, civic, cuts, delsol, dieing, driving, dying, integra, jumped, push, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
