Can't Take Key OUT!!!
Old 02-08-2005, 08:46 PM
Senbonzakura's Avatar
Default Can't Take Key OUT!!!
My friend's 2000 Civic key is stuck in the ignition and it won't come off.
The key is stuck and its not the origianl key. Its the copy key and its stuck in there.
Also when i turn it half way, it says its in Drive mode which i think is why i can't take out the key. But then i can also move the transmission back and forth to drive and park. But when i turn the key half way it still says its in Drive mode and it turns off.
Do i have to disassmble the steering wheel and its hatch to get the key out?
Old 02-08-2005, 08:50 PM
3.point.2's Avatar
had this happen, tried taking off the steering wheel and all and it still wouldnt come out so i got pissed and hit the key and then i pulled it out. dont know if thats the best solution but if you want you might want to try it.
Old 02-08-2005, 08:54 PM
_Cyclone_'s Avatar
Default Re: Can't Take Key OUT!!! (Kyo Kusanagi)
First try holding the shifter forward hard as you try to take the key out.
Old 02-08-2005, 08:56 PM
Default Re: (h23eg)
I did the hard way. Don't know what i did but its off and working fine. Going to bring it to the shop and see if any damage was done. Thanks again
Old 02-08-2005, 09:00 PM
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default Re: (Kyo Kusanagi)
You can't take the key out because the button on the automatic shift **** is stuck...
granadablanca
11-22-2011 08:35 AM
1sikhatch
04-09-2010 08:41 AM
loup05
08-30-2005 04:09 PM
fkguitar
08-06-2005 10:03 AM
dc2go
05-23-2005 10:33 AM
Quick Reply: Can't Take Key OUT!!!
