Can you run a spare tire on a front wheel?
Old 10-04-2008, 10:36 PM
93CamaroLT1's Avatar
Default Can you run a spare tire on a front wheel?
Would running a spare tire on the front of a civic (no limited slip) [freak] up the dif?... wouldn't the spare tire would be spinning faster than the normal size tire?
Old 10-04-2008, 10:41 PM
jimmy o.'s Avatar
it should be fine for temporary use just dont run too fast on it
Old 10-05-2008, 06:50 AM
thumper64's Avatar
Don't do it unless it's a really short trip to get it fixed. It can be done, as a girl I know did, but it's a horrible idea. The handling and braking will be screwed up, the diff will work extra hard, and logically the transmission fluid will break down faster. Put a good rear tire on the front, or change your trans fluid. If nothing else, it's probably due for it anyway.
Old 10-05-2008, 07:10 AM
Red99Si's Avatar
Default Re: Can you run a spare tire on a front wheel? (93CamaroLT1)
you can run a spare in the front, but they are only made to get you home or to a shop. Your car will pull in a certain direction more and your turning will be dirrerent. From what i have heard, you are not suppose to go faster than around 60mph
hometheaterman
09-04-2007 10:33 AM
hondaguyef
09-29-2004 02:52 AM
sTraNdeD
06-10-2004 11:51 PM
Dino_D
09-04-2003 01:23 PM
tonydatyga
04-21-2002 03:27 PM
Quick Reply: Can you run a spare tire on a front wheel?
