cam and crank oil seal replacememnt, need help asap!
H-T Order of Merit
ok, I'm doing my timing belt, water pump, etc. right now and I'm at the point where I need to replace the oil seals on the camshaft and crankshaft. Someone said before to use a small screw driver to pull it out but I honestly don't see how I can do that. Can anyone give me some quick tips on how to get those seals out?
Your help is appreciated, thanks.
Re: cam and crank oil seal replacememnt, need help asap! (TouringAccord)
You can use a sharp pick, but be sure not to score the metal around the seals. Stab the seal right in the middle (softest part/all rubber) and pull it out. I think I even used a small screw once.
H-T Order of Merit
Re: cam and crank oil seal replacememnt, need help asap! (t0p_sh0tta)
so just use a small pick, poke the seal right in the middle (between cam and head jernal (sp?)) and pull it out? Thats it?
H-T Order of Merit
yep, thanks. I got that done, it was easier than I figured it would be.
now I have another issue
https://honda-tech.com/zerothread/2015875
TOO MUCH TORQUE
02-13-2015 06:13 PM
NeverOut215
09-30-2011 08:56 AM
pityocamptes
03-16-2010 03:34 PM
Nathan007
06-10-2009 03:20 PM
