A/C Tensioner.. Won't move!! Need Help!!
Ok.. I'm trying to replace my A/C belt and the stupid tensioner WILL NOT BUDGE at all. I pounded it with a hammer, penetrating oil, nothing..
Anything else I can do to get that stupid belt of?!!?
Unceasing Measure
Re: A/C Tensioner.. Won't move!! Need Help!! (civicmon)
You live in San Diego. There's no reason to have air conditioning on your Civic. If you wrestle with the pulley some more and have no luck, just take the bastard off and enjoy the free hp.
i recently took mine off... it was a bitch but it eventually broke loose. get more leverage and give it hell. try a breaker bar. i used a little 14mm box end wrench on it, and was pulling HARD toward the front of the car. after about 3 minutes it finally gave in, my hand flew forward and i cut my wrist on something up there. be careful... i bled pretty bad.
Re: A/C Tensioner.. Won't move!! Need Help!! (jwn7)
I think you're thinking of the AC or the Alternator one... because I already got those off.
This one has a pulley that slides up and down (in theory) but I can't get it to head back down. I tried banging it like a madman to try to get it to budge with no luck.
Any other tips?
Any other tips?
I to Smooch Pickle
ac tensioner?? my AC tensioner is just a 10mm bolt bolted onto the AC bracket? is that what you are talking about?
Re: A/C Tensioner.. Won't move!! Need Help!! (mingchi69)
yeah but the thing's adjustable, in theory. to take that off would involve taking off the ac compressor but that's probably my only option right now.
wouldn't be so bad but I gotta write a paper entirely in japanese tonight.. due tomorrow..not looking forward to it.
I to Smooch Pickle
hmm.. there's a bolt that holds the AC tensioner pulley, but make sure you loosen the tensioner bolt first. Its a 10mm long bolt and a 12mm nut. Those should be really easy to take off. If you are having trouble getting to the bolt that holds the pulley, u can take off your driver side engine mount and the lower engine mount (by the crank pulley), and let your engine sag down. From that, you can get access to the pulley. Hope that helps.
the bolts are frozen solid, and I can't get them to move at all.
I just took the whole pulley/bracket off and left off the ac belt for the meantime. When I get the time, i'll try to pry it all apart and put it back together, definately before the summer here.
-InteGSR-
02-02-2010 06:39 PM
