93 del sol ls swap - input needed on OBD2 to OBD1 conversion
Old 08-03-2011, 10:11 AM
Ayyxbro's Avatar
Icon2 93 del sol ls swap - input needed on OBD2 to OBD1 conversion
Hello everyone, just bought a 93 del sol si, and an ls swap. The swap is obd2, what parts do i need to convert the swap to obd1, and to be able to drop it in the car? I will eventually be running lsv turbo, not sure if that helps.
Thanks,
Jayy
Old 08-04-2011, 01:50 AM
Josueneta's Avatar
Default Re: 93 del sol ls swap - input needed on OBD2 to OBD1 conversion
Hey I got the Ls swap on my 93 Del Sol I'm in the proses of looking for a vtec head for the LSv and I also wanna boost it after that
Well me I got a B18a1 it use to be obd0 but now it's obd1 I took it to a shop to do the wiring I don't think they switched out sensors tho but hope to see the build soon
Old 08-04-2011, 02:14 AM
BrandonR's Avatar
An OBD-1 Distributor.
Old 08-04-2011, 08:41 AM
B18CivicEJ8's Avatar
Thanks,
Jayy
What year is the LS swap? If it's a 96-99, then you'll need an OBD2A Integra harness. If it's 00-01, then you'll need a OBD2B Integra harness. 100% plug and play. The OBD2 Integra harness splits at the shock towers just like your Del Sol. So you don't have to swap injectors, alternators, or distributors. Just plug in and go.
Old 08-04-2011, 08:47 AM
portenio78's Avatar
If your swap came with an engine harness, just use that and everything plugs in to the Sol's harness. Then just get your ecu chipped and put a stock progam on it.
Old 08-04-2011, 11:51 AM
Hidenplanvew's Avatar
Dizzy and injectors are onlything obd2... easy swap you can get adaptors too
Old 08-04-2011, 01:27 PM
Ayyxbro's Avatar
The engine is from an 98 integra. The swap came with everything but a shift linkage, which wouldnt have helped me anyway. But motor, tranny, axels, half shaft, ecu harness, ect. everything was pulled from the same car.
Would i want to run the ls ecu? or a p06 for the time being?
So i will need an obd1 dizzy? And a friend of mine told me i could use the injectors that are on my z6 now, is that accurate?
Old 08-04-2011, 01:33 PM
No, you won't need an OBD1 dizzy or injectors. Like I said, if you have the LS harness, use that and it will plug right in. You don't have to swap anything. You have the easiest to swap platform out there. Run the LS ecu, it's for the LS engine. Why would you run a p06? You'll lean out if you do that.
Old 08-04-2011, 01:50 PM
Ayyxbro's Avatar
alright thats great!
And a friend of mine said that if i didnt have it i could run a p06 and it it work just as well.
Old 08-04-2011, 01:51 PM
Your friend is wrong. It will run. But it will run lean. Lean is bad.
Old 08-04-2011, 05:52 PM
portenio78's Avatar
He cant run the 98 ls ecu because it wont plug in directly without an adaptor. IMO it would be easier to just chip his P06 and call it good?
Old 08-04-2011, 06:43 PM
HAMOTORSPORTS's Avatar
Drop the swap right in just as it was in the Integra, use a stock 94-95 LS ECU and your done. All you need is a del sol VTEC shift linkage.
Old 08-04-2011, 06:50 PM
tj_h22's Avatar
WOW pretty easy stuff, i'd find a OBD1 P75 ECU , they're like a dime a dozen
MadCoder
07-18-2011 05:42 PM
kdoggparker
10-28-2010 11:51 AM
DuVaL rAcEr
05-05-2008 08:37 PM
93LSTurboSol
11-04-2004 07:53 AM
terribl3jon
09-02-2004 04:58 PM
Quick Reply: 93 del sol ls swap - input needed on OBD2 to OBD1 conversion
