a/c condensor fan fuse keeps blowing - Honda-Tech
Old 10-09-2007, 07:43 AM   #1
FLCivic's Avatar
Default a/c condensor fan fuse keeps blowing
I have a '97 Civic which the a/c compressor doesn't come on. I have found the problem to be a blown condensor fan fuse. The relays seems to be OK but the fuse keeps blowing whenever I turn the a/c on. Any other suggestions where to check?
It's still hot out here in FL.
thanks
FLCivic is offline   Reply With Quote
Old 10-09-2007, 01:37 PM   #2
vrrodri's Avatar
check the condensor fan motor, if you apply voltage to it, does it run? Does it run slow? When they start to die, they run slower than the radiator fan.
Maybe the motor is stuck and it blows the fuse, or you have a shorted wire by the consenser assembly. There should also be a groun going to the compressor.
vrrodri is offline   Reply With Quote
Old 10-09-2007, 01:58 PM   #3
Duane_in_Japan's Avatar
Default Re: (vrrodri)
Turn on the AC, have a friend do it, watch both fans, turn off the AC and the condensor fan should stop much quicker, if its going bad. You could have a burned relay, burned relay socket, burned wire in the fan circuit, loose or corroded ground connection, burned or corroded connector in the fan wiring, bad fan motor / brushes. Carefully touch both motors to see how hot they get, the hotter one should be bad.
Motors and relay sockets are at the top of the list.
Duane_in_Japan is offline   Reply With Quote
Old 10-09-2007, 01:59 PM   #4
circuitEG6's Avatar
X2!!
circuitEG6 is offline   Reply With Quote
Old 10-09-2007, 05:15 PM   #5
FLCivic's Avatar
Default Re: (Duane_in_Japan)
When you say both fans do you mean the radiator fan and condensor fan?? Also I disconnected the condensor fan and the fuse still blew when I turned the a/c on. I guess I can rule out the fan. Also anyone have the schematics for the electrical part of the a/c?
thanks for the replies
Old 10-09-2007, 05:31 PM   #6
impr323's Avatar
Default Re: (FLCivic)
Gimme your email and ill send you a 96-00 helms manual w/ schematics
impr323 is offline   Reply With Quote
Old 10-09-2007, 05:34 PM   #7
-JSpecEk*9-'s Avatar
Default Re: (impr323)
you have a short so look at your wiring.
-JSpecEk*9- is offline   Reply With Quote
Old 10-09-2007, 05:55 PM   #8
FLCivic's Avatar
Quote:
thanks but I just got it thanks to google
Old 10-10-2007, 08:09 PM   #9
vrrodri's Avatar
shorted wire or bad ground...
Old 12-18-2007, 05:37 PM   #10
FLCivic's Avatar
Still have this problem. I have replaced the condenser fuse, condenser fan, a/c unit and even swapped out the fuse box without success. I have found that the short occurs only when I turn on the a/c.
Any suggestions??
HELP A/C condensor fuse keeps blowing bionichicken Honda CRX / EF Civic (1988 - 1991) 2 08-01-2012 10:04 PM
Help with a/c demons CLE Honda CRX / EF Civic (1988 - 1991) 10 08-14-2006 10:05 PM
a/c blowin fuse danteisme Acura Integra 2 08-05-2004 05:29 AM
Please Advise - I'm Hot!! judyj Honda Civic / Del Sol (1992 - 2000) 3 08-04-2002 01:03 AM
Short in Condensor Fan Fuse judyj Honda Civic / Del Sol (1992 - 2000) 1 08-03-2002 09:58 AM
Tags
2001, 636, ac, blowing, blown, brushes, civic, condenser, condensor, fan, fuse, honda, kawasaki, motor, prelude
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
