Erratic Idling 94 Del Sol DoHC vtec
Old 07-23-2012, 12:33 PM
Mylinh's Avatar
Default Erratic Idling 94 Del Sol DoHC vtec
Hi,
i have a 94 del sol and is suffering from erratic idling.
Things I've done-
-Changed ICAV
-Filled Radiator Coolant
This problem is still not fix despite my efforts. Does anyone have any information to this problem please let me know.
THanks in advancee
Old 07-23-2012, 12:35 PM
EK9
Dc4LsTeG's Avatar
Default Re: Erratic Idling 94 Del Sol DoHC vtec
Have you bleed the coolant system?
Old 07-23-2012, 01:21 PM
BoRiCuA's Avatar
I dont know if bleeding your coolant would have anything to do with your erratic idle problem, but it can be various things, aree you throwing any codes?
Old 07-23-2012, 04:56 PM
slowcivic2k's Avatar
When is the idle erratic? Cold, hot?
When did this problem start?
How erratic are we talking, Honda's have all kinds of erratic idling.
Low coolant may prevent the FITV from closing on time, producing a fast warm idle, and thus an idle surge. The IACV and FITV are two totally different components, do not get them confused.
You most likely have a manifold leak somewhere. Use brake parts cleaner to identify the source of the leak, indicated by racing of the engine as the cleaner finds its way into the intake. Replace those parts, and confirm the fix.
Would not be a bad idea to adjust base idle after fixing the true cause of the problem.
Old 07-23-2012, 04:59 PM
Former User's Avatar
Click FITV link in my signature.
BaronVonZ
05-19-2015 09:04 PM
DerekHollister
04-21-2015 02:23 PM
johnnieh93
05-17-2008 02:15 PM
Solless16
11
06-14-2005 07:51 PM
Quick Reply: Erratic Idling 94 Del Sol DoHC vtec
