buying a junk yard engine how to check if its good? - Honda-Tech
Old 04-08-2012, 01:03 AM   #1
Default buying a junk yard engine how to check if its good?
so when pulling an engine at pick and pull obviously you cant start it.
and i already bought a junk engine that i cant return cuz its been way past 90 days.
it has a rod knock and all kinds of leaks
so im gonna have to buy another long block y7 to replace it or a z6
whats the best gameplan to check as much as i possibly can without tearing it down.
i know for one to rotate the crank with spark plugs in to check for burnt valves there will be much less force if one of the cylinders is leaking compression.
but how ot check if the engine has bad bearings or rod knock
so to keep track
check for body damage
if no body damage then engine is the problem if rolled over also bad engine
if hit on the front, engine mounts or exhaust manifold bolt holes might be stripped
1 spin the crank to see if its seized up or spins freely. if theres no compression the crank will spin much easier with spark plugs in.
2 pull spark plugs and see what they look like and ook inside spark plg holes
3 pull valve cover off and check for buildup and signs of overheating or low oil
4 pull oil pan and check for signs of overheating( black color rod caps and black color crank around bearings) also metal shavings in oil pan
5 sings of heavy oil or colant leaks around engine bay.
6 ask for recorded mileage from junk yard.
7 try to get a warranty
raverx3m is offline   Reply With Quote
Old 04-08-2012, 01:48 AM   #2
94preludeguy's Avatar
Default Re: buying a junk yard engine how to check if its good?
In my experiences of the hundreds of junkyard trips I've made.. If the car has enough body damage to total it out, more then likely that motor is good. If the car has no body damage or very minor, more then likely the car was scrapped because of a drivetrain issue.
94preludeguy is offline   Reply With Quote
Old 04-08-2012, 02:09 AM   #3
good point.
is there a way to check for bad bearings?
Old 04-08-2012, 04:21 AM   #4
You could check the oil pan for metal flakes. I would just change to new bearings though.
morbius18 is offline   Reply With Quote
Old 04-08-2012, 07:02 AM   #5
Quote:
That's what I always tell people. If the body is decent then the motor or trans likely died. And check their warranty because it's usually not money back but actually just a yard credit.
Best way to check is to turn it over by hand first. A lot of these cars you can start if you bring a battery and with a bit of work and car part swapping bam its complete.
zcegdx is offline   Reply With Quote
Old 04-08-2012, 07:11 AM   #6
fabioso's Avatar
If the cluster is still in the car check how many miles along with the suggestions above. No point in pulling a motor with 300k IMO.
fabioso is offline   Reply With Quote
Old 04-08-2012, 07:14 AM   #7
fabioso's Avatar
Also smell the oil, And pull the valve cover. Check for a burnt smell and for sludge. I would pass if the oil is really dirty or burnt and Obviously milky.
Old 04-08-2012, 02:34 PM   #8
Seagull Management
94EG8's Avatar
Take a flashlight with you, remove the oil cap and shine it under the valve cover, if it looks nice and clean chances are really good it's a good engine. If it's full of old burnt on oil and sludge pass. If it's still in the car take the rad cap off and check for rust, sludge or oil in the coolant. There's no easy way to check for a spun bearing without pulling the pan, but honestly if it looks clean under the valve cover 9 times out 10 it's a good engine.
94EG8 is online now   Reply With Quote
Old 04-08-2012, 02:45 PM   #9
Tw34k's Avatar
Also try removing the valve cover and inspecting the valvetrain. It should be a golden bronze color if the engine is low miles and had regular oil changes. If you have a black gunky sludge on anything other than just the bottom of the oil pan then the engine may be more suitable for a rebuild rather than startup. Learning how used oil should smell is a great benefit to inspecting engines as well.
If the engine still has oil I like to drain off the first bit and last bit into a small seperate pan to screen for shavings.
Tw34k is offline   Reply With Quote
Old 04-08-2012, 06:51 PM   #10
Oh look, I can change this
deschlong's Avatar
Incidentally, what is the likelihood that a vehicle with body damage has sustained (non-obvious) injury to the head or block? What should you look for?
deschlong is offline   Reply With Quote
Old 04-08-2012, 07:05 PM   #11
Seagull Management
94EG8's Avatar
Quote:
If it rolled I'd pass on the engine, running upside down tends to ruin an engine pretty quick. Other than that check very closely for cracks around mounts. Someone told me years ago they had horrible luck buying junkyard B16A transmissions from smashed up cars, they kept blowing differentials through the side of the case, he finally started blaming it on the extremely abrupt stop with the car still in gear, something to think about.
Old 04-08-2012, 08:32 PM   #12
CivicB18C1's Avatar
do a leak down test.
drain oil, or a bit of it from the pan and check it out. look for metal shavings and if it looks milky.
see if you can put a socket on the crank bolt and rotate it by hand
pull the plugs and take a peak at them
CivicB18C1 is offline   Reply With Quote
Old 04-08-2012, 09:23 PM   #13
i have an inspection camera that can fit through oil pan hole.
looking at the rod caps i know when they are black is bad because of running with no oil. is black rod cap always an indication of bad bearing or can bearing be bad without any signs?
Old 04-08-2012, 09:39 PM   #14
Arthas's Avatar
Interesting thread, Ive always been curious at the engine.
Good luck though! Whenever I see a Z6 or a Y8 at the junk yard, theyre gone by the time I blink.
Arthas is offline   Reply With Quote
Old 04-08-2012, 09:58 PM   #15
nihad's Avatar
on ex si hx engines you can take off the vtec solinoid off usually there is some metal in there if its bad..
nihad is offline   Reply With Quote
Old 04-08-2012, 11:44 PM   #16
im sure everyone figured were talking mostly single cam prelude and ls motors.
chances of finding a b series vtec motor are pretty slim...
How to build a "reliable" lsvtec/b20vtec bambam All Motor / Naturally Aspirated 2144 01-12-2017 04:58 PM
Any degree of rod knock fixable? iwannarace All Motor / Naturally Aspirated 10 06-13-2015 07:14 AM
check list for buying used parts(b series) raverx3m Tech / Misc 9 03-12-2015 11:47 AM
What to check when buying a Car PerfectionIsKey Honda Civic / Del Sol (1992 - 2000) 16 01-14-2013 03:41 PM
Rod Knock? Complete teardown, can't find the problem Rabid Honda Civic / Del Sol (1992 - 2000) 0 09-09-2007 10:04 PM
Tags
600, bad, block, blown, cbr, check, determine, engine, f4, good, honda, junkyard, long, motor, overheated
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
