burning oil...
Old 05-08-2014, 11:54 AM
giovannie23's Avatar
Default burning oil...
My civic gots a bad oil leak I'm assuming as sooni. As it warms up it smeels like something is burning kinda like burning rubber smell..
I check it out and and saw the smoke coming from the driver side of the engine but the bottom kinda by where the oil pump it...
Anybody had this issue?? Any help is appreciated thanks...
Old 05-08-2014, 12:04 PM
The Grumpiest
grumblemarc's Avatar
Default Re: burning oil...
Could be anything. Seals. Gaskets. Find out exactly where.
Old 05-08-2014, 12:52 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Could be a loose or worn accesory belt. Or an alternator/PS pump bearing that's starting to sieze.
Old 05-08-2014, 01:23 PM
Idk I think it might be a crankshaft seal and leaked onto the timing belt so the timing sliped a tooth and bent my valves pretty good so engine won't start..I just wanted to know if oil pumps tend to leak oil or do the seals just go bad?
Old 05-08-2014, 01:27 PM
The Grumpiest
WTF are you speculating for? So the damage has already been done and you want to play the "what could have cause this? " game?
Old 05-08-2014, 01:39 PM
I never narc'd on nobody!
NotARaCist's Avatar
Clean the engine bay. Attack it with degreaser and some scrub pads. Get that **** sparkling. Once you've done that, then you can start pinpointing where you're leaking oil from.
Old 05-08-2014, 02:14 PM
And your point is ???
I'm lookimg for experienced honda heads not dicks...
Take your miserable life else where bro
Its actually not even my car it was brought to me to fix
Thx anyway.
Old 05-08-2014, 02:19 PM
Yea man I degreased it but can't find any leaks it seems like it only leaked when the car was driven...I'm just gonna pull the head and take the tb off and see if I can spot any oil spills hidden behind the bottom timing cover
Thx man
Old 05-08-2014, 02:22 PM
NotARaCist's Avatar
If it's leaking, and if you actually cleaned your motor, there would be visible residue, even if it's only leaking when you drive. Also, if you think it's only leaking when you drive, secure it on jack stands and get under it to inspect while someone "drives" the car.
Old 05-08-2014, 02:35 PM
B serious's Avatar
He said it won't start now.
Old 05-08-2014, 03:56 PM
I mean there's like res around the lower timing cover which makes me think its something in there I hust gotta take it apart...
But the car doesent run man the valves are bent
Old 05-08-2014, 04:05 PM
The Grumpiest
And again. Car doesn't run so there will be no more leaks. Stop bullshitting, speculating and start pulling parts and find the leak. You have to do it anyway with the valves all fucked up anyway.
So what I said still stands. It makes no difference where it "might" have come from since the engine is already broken. Now is your chance to pull it apart, freshen it up and tell US what is was that was causing the leak.
Old 05-08-2014, 08:57 PM
Yea ill be letting you guys know within a couple days...
Thanks again
siva_s
Honda Civic (2001 - 2005)
05-14-2019 08:58 AM
Josueneta
05-07-2010 01:43 PM
gnccracer20
11
02-04-2009 03:14 AM
TekSI
12-14-2004 07:52 AM
ID_ten_T
02-04-2004 08:27 PM
Quick Reply: burning oil...
