Bumper to fender bolt/screw - Honda-Tech
Old 04-22-2011, 11:33 AM   #1
Default Bumper to fender bolt/screw
Does any body know any tricks to get the plastic grommet to stay in the fender so you can use the OEM phillips screw to hold the bumper to the fender?
The plastic grommet I am talking about is number 11 in this picture
My driver side fender was using some crappy metal bracket which rattled and didn't hold the bumper on close enough to the fender. So I bought a new plastic grommet/screw so I could put it the bumper on the OEM way like the passenger side, but I can't get the plastic grommet to stay in the hole.
Dekorum is offline   Reply With Quote
Old 04-22-2011, 11:43 AM   #2
I'm not Rick!
rick_rabies's Avatar
Default Re: Bumper to fender bolt/screw
superglue.
epoxy.
jbweld.
rick_rabies is offline   Reply With Quote
Old 04-22-2011, 02:30 PM   #3
Anything else? I don't want to jump into putting superglue on my fender unless its my last option.
Old 04-22-2011, 02:35 PM   #4
The Grumpiest
grumblemarc's Avatar
With that piece on the front it kept popping out so I zip-tied it until I could figure out something better. Didn't like having to do it but 2 of them hold on pretty well and isn't permanent.
grumblemarc is offline   Reply With Quote
Old 04-22-2011, 04:50 PM   #5
TwoFaced's Avatar
^x2
TwoFaced is offline   Reply With Quote
Old 04-22-2011, 04:53 PM   #6
lunareg's Avatar
Quote:
lol I came in here to see what part it was too, my bumper is zipped tied on one side. it works obviously, but its not really lined up right lol
lunareg is offline   Reply With Quote
Old 04-22-2011, 05:46 PM   #7
civicsmoke's Avatar
make sure the lip on the fender is flush with the bumper, then get yourself some stainless steel bolts and nuts, use washers on both sides.
civicsmoke is offline   Reply With Quote
Old 04-22-2011, 06:06 PM   #8
HaZyEk9's Avatar
^x3
I have basically my whole front end zip tied and you arent even able to tell the diffference. Get the heavy duty black ones with the metal lock and youll be good!!! Dont use the cheap white ones you can see and they arent as durable. Atleast until you figure what else to do,but ull prolly end up leaving it! Human instict
HaZyEk9 is offline   Reply With Quote
Old 04-23-2011, 01:17 AM   #9
s13hero's Avatar
Quote:
This is what I did too.
s13hero is offline   Reply With Quote
Old 04-23-2011, 10:00 AM   #10
You used an actual nut? Thats kind of hard to have to hold that with a wrench while you are tightening the bolt, since the area is pretty tight to work in. Most people use the metal bracket with the nut welded onto the back, like in the OEM lip hardware kit.
Old 04-23-2011, 10:14 AM   #11
EJ1civic coupe's Avatar
Quote:
then if you dont wanna do that option then why dont you buy the OEM hardware kit..duh
theres so many options out there on what to do..the little white plastic peice isnt gonna last for ever..mine eventully started coming out as well and all i did was use the nut and bolt option..its not hard at all to get in there and tighten it up if you kno what your doing
EJ1civic coupe is offline   Reply With Quote
Old 04-23-2011, 10:17 AM   #12
lunareg's Avatar
yeah if you take the corner light out, its easy as hell to get at it.. I just went for the zip tie since its easy to cut it out if you need to get your bumper off, lol
Old 04-23-2011, 10:18 AM   #13
Ok, cool. Just trying to see some ideas as to what others are doing.
Old 04-23-2011, 10:52 AM   #14
Quote:
also turn the wheel inwards so you can get more leverage if you wanna use bolts/nuts..and zip ties are easy as hell to..5 screws up top..2 bolts on bottom and 2 snips on the sides and there you go the bumper is off less then 3 mins
Old 04-23-2011, 03:44 PM   #15
sde780's Avatar
The more you screw the screw in, the better the plastic clip holds. Might want to make sure the fender tab that it goes in isn't bent. If it is, bend it back
sde780 is offline   Reply With Quote
Old 04-23-2011, 03:55 PM   #16
Yeah thats one of my problems. My fender tab is so mangled. Its just just a staight tab thats bent down. Bending it back still leaves it almost like a piece of paper that was once crumbled. I can't figure out how to straighten it completely since I only have a needle nose plier.
Old 04-23-2011, 04:45 PM   #17
To get an idea of what I'm talking about...
Good side
Bad side
Old 04-23-2011, 04:55 PM   #18
Geeze does evrybody use zip ties? i have them too lol
C4_Gsr_civic is offline   Reply With Quote
Old 04-23-2011, 06:24 PM   #19
sde780's Avatar
Just use a ziptie. I used a huge plier that exhaust shops use and got mine somewhat straight, but it still wanted to pop out with my fiberglass bumper
How can I wire my amp? ALDJ253 Honda Accord (1990 - 2002) 4 03-06-2014 08:25 PM
OEM VX rear diffuser installation? fungus mungus Honda Civic / Del Sol (1992 - 2000) 10 04-22-2011 10:44 PM
Just picked up some mudguards, Have a few questions.. kaluwa3 Honda Civic / Del Sol (1992 - 2000) 17 10-04-2008 03:07 PM
where can i get a cheap set of b series grommets and screws? Hanmin Honda Civic / Del Sol (1992 - 2000) 3 08-09-2008 12:50 PM
Has anyone replaced their fender liner? rayzian Honda CRX / EF Civic (1988 - 1991) 9 09-09-2007 04:23 PM
Tags
1992, bolt, bolts, bumper, bumpers, civic, dont, fender, hold, honda, kind, line, metal, side, size, tie, zip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
