Broken LCA-hub bolt
Old 05-12-2006, 05:37 PM
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default Broken LCA-hub bolt
I was installing some coilovers on a 99 civic and the 14mm bolt that connects the lower control arm to the hub (NOT the bottom shock bolt) broke. I could care less about the shock bolt because I'm replacing the whole LCA assembly. So at first I was thinking about getting the bolt out extractor kit from sears after drilling a hole through it but I figured I wouldn't get anywhere because the bolt is seized through the metal sleeve in the bushing.
The question is the bolt (#19 near the trailing arm/hub assembly) threaded only through the NUT part at the back of the trailing arm/hub? Because if it is then I'm just planning of grinding that welded nut off, punch the rest of the bolt out, and buy a new nut. Also what is the thread pitch on this 14mm bolt? M10 1.25?
Old 05-12-2006, 05:42 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Broken LCA-hub bolt (BrokeAssPinoy)
When this has happened to me in the past, I would use a sawzall or pneumatic cutting wheel to begin cutting the welded nut away from the LCA and then I would move to an air chisel once the gap was big enough. It's worked for me in the past, it should work for you as well .
And yeah, 10/1.25 should be the correct pitch. Then again, if you're going to use a new nut, simply make sure the bolt you plan on using fits in it
Old 05-12-2006, 05:53 PM
Default Re: Broken LCA-hub bolt (Archidictus)
cool so it is only threaded through the nut then right and not through the whole sleeve in the bushing? Once I've cut out the wleded nut, I can just punch the rest through?
Old 05-12-2006, 06:04 PM
CivicBlack's Avatar
yeah you should be able to punch it through as long as it will come loose and go through.
Old 05-12-2006, 07:33 PM
spoonracer84eg's Avatar
Default Re: Broken LCA-hub bolt (CivicBlack)
Its happened to almost everyone. Search and you will find what you need.
Old 05-12-2006, 07:34 PM
Unceasing Measure
Default Re: Broken LCA-hub bolt (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">Its happened to almost everyone. Search and you will find what you need.</TD></TR></TABLE>
We actually took care of it already, noob. Move along, child.
Old 05-12-2006, 09:15 PM
yep I searched ahead of time even before I messed with the bolt. Just wanted to make sure of the bolt's thread pitch. thanks guys
Jdmglenn
Welding / Fabrication
12
01-05-2009 10:13 PM
JDM978
10-01-2006 06:30 PM
Eg253
Suspension & Brakes
30
06-24-2006 05:10 AM
OneDirection
Suspension & Brakes
13
01-17-2005 07:19 AM
Quick Reply: Broken LCA-hub bolt
