Broken hood cable
Old 04-08-2012, 05:03 PM
jksmith's Avatar
Default Broken hood cable
My hood cable is broke and I need to get my hood open to replace it. Anyone have a trick or easy solution to pop the hood without using the latch?
Car is a 99 ek coupe
Old 04-08-2012, 05:08 PM
andyz's Avatar
Default Re: Broken hood cable
Hard to get to the latch without taking the bumper off.
Furthermore, to replace the cable, you have to take the driver side quarter panel off.
Old 04-08-2012, 05:09 PM
EK9
Dc4LsTeG's Avatar
Do you know where the cable is broken?
Old 04-08-2012, 05:19 PM
jksmith's Avatar
yes but can not get hood open to get to the fender bolts.
i do not, i dont know if its actually broken in half, i think it stretched out and wont pull the latch enough to pop the hood.
Old 04-08-2012, 05:20 PM
jksmith's Avatar
I also can not get the grille off or the bumper off without popping the hood so cant get anything in there to pry the latch, and i have tried sticking pliers and pulling the cable with no success,
Old 04-08-2012, 05:31 PM
hondacl9's Avatar
hood cable passes behind the front bumper is on that site
Old 04-08-2012, 08:13 PM
jbpnoman's Avatar
If you think it's just stretched, and not broken, unbolt the handle under your dash, and grab it with some needle nose pliers. It also helps to wrap some of the wire around the tip of the pliers, for better grip.
soodominican
12-06-2008 01:41 PM
Redemption
08-14-2008 04:23 PM
ZCHF
31
03-15-2004 06:20 PM
sidewayz
03-12-2003 07:28 PM
LoudLude
02-13-2003 05:44 AM
Quick Reply: Broken hood cable
