broke rear lower shock bolt. help
Old 03-19-2012, 01:21 PM
Marvin1985's Avatar
Default broke rear lower shock bolt. help
part number 15 here
broke the head off anyone have any tips/advice on getting it out?
Old 03-19-2012, 01:22 PM
Marvin1985's Avatar
Default Re: broke rear lower shock bolt. help
its a 99 civic hatch
Old 03-19-2012, 01:45 PM
JDM_teh_WIN!!'s Avatar
This happens all the time. Just curious, what are you doing? putting on new lower control arms or putting on new shocks?
Old 03-19-2012, 02:27 PM
Marvin1985's Avatar
new shocks/coilovers
Old 03-19-2012, 02:43 PM
Well my suggestion to you is that you buy new lower control arms. The bushing that the bolt is seized in is junk. I would get a good steel cutting hack saw blade and start cutting the bolt on the other side between the shock and the lower control arm. Then get a vise grips and turn the rest of the bolt out of the nut welded on the shock. That should get your shock loose from the control arm.
Some people will say drill it out. It's not how I would do it but it's another option.
You can replace the bushing it self but it will be a real pain to do.
Old 03-19-2012, 03:07 PM
Master Detailer
98civdx's Avatar
Drop the LCA/shock in peice. Cut the welded nut off, and try to wiggle the shock off the LCA, or try to pound the bolt out.
OR drop it all, and replace everything. OEM control arms are $67 each from mejestic, but the bushings aren't that hard to replace seperatly.
Old 03-19-2012, 03:14 PM
civicjunkie17's Avatar
Which side is it? I have a lca from my 99 coupe. One side was frozen and the other side was fine. I just replaced the entire assembly with aftermarket lcas. Let me know if you're interested!
Old 03-19-2012, 03:27 PM
Marvin1985's Avatar
driver side but ima buy new LCAs and get new bolts from honda. for now my front is lowered and rear is stock. poop
Old 03-19-2012, 03:42 PM
Kohen's Avatar
OP, you can probably find a pair in the market place or on craigslist or something for more like $30. I'm selling two today for $20. And I've seen them go for $10. Also check junk yards.
Old 03-19-2012, 04:26 PM
Yeah, I'm selling a single driver side one for $10 because the same thing happened to me.
Tong.Y
06-14-2010 12:33 AM
jdmturbo1127
Suspension & Brakes
09-25-2007 09:36 AM
inTeGra_LivesOn
01-22-2005 12:17 PM
puhlode
02-02-2003 12:24 PM
Quick Reply: broke rear lower shock bolt. help
