brakes making hissing sound when braking - Honda-Tech
Old 06-12-2011, 10:08 PM   #1
swizz977's Avatar
Default brakes making hissing sound when braking
what would this mean everytime i brake i hear a hissss
swizz977 is offline   Reply With Quote
Old 06-12-2011, 10:48 PM   #2
virgineg6's Avatar
Default Re: brakes making hissing sound when braking
It means you need to check your brakes and possibly replace your pads
virgineg6 is offline   Reply With Quote
Old 06-13-2011, 05:25 AM   #3
swizz977's Avatar
i just di all that
Old 06-13-2011, 05:47 AM   #4
swizz977's Avatar
oh and it only hisses when im rolling n press the brakes not when im already stopped
Old 06-13-2011, 05:48 AM   #5
The Grumpiest
grumblemarc's Avatar
Quote:
Talk about lack of info.
Are you sure it's a hissing sound and not a light grinding noise?
grumblemarc is offline   Reply With Quote
Old 06-13-2011, 05:57 AM   #6
swizz977's Avatar
no its deff hissing just replaced all the brakes too
Old 06-13-2011, 06:09 AM   #7
swizz977's Avatar
also my pedal is very soft and mushy
Old 06-13-2011, 06:11 AM   #8
Canuckian
Bleed your lines several times to get all the air out then come back with an update.
Lugzilla is offline   Reply With Quote
Old 06-13-2011, 06:18 AM   #9
Ek Forever y0!
Libertariat's Avatar
Did you use brake caliper grease on the back of the pad when you installed them?
Libertariat is offline   Reply With Quote
Old 06-13-2011, 06:25 AM   #10
swizz977's Avatar
not sure but i had to get new calipers in the back
Old 06-13-2011, 06:27 AM   #11
The Grumpiest
It's a yes or no question. You either did or did not. If you did not, which you probably didn't, that would most likely be the cause of the "hissing".
Old 06-13-2011, 09:31 AM   #12
swizz977's Avatar
the hissing is coming from the rear brakes
Old 06-13-2011, 09:40 AM   #13
Ek Forever y0!
Old 12-22-2011, 07:58 AM   #14
ludedude48's Avatar
My wife's TL3.2 is doing the exact same thing. Its not the rear brakes. It sounds more like someone is letting the air out of a tire - and its coming from under the steering column.
ludedude48 is offline   Reply With Quote
Old 12-22-2011, 08:25 AM   #15
purgat0ry's Avatar
Did you bleed the lines after the fact?
Make sure you installed everything properly.
purgat0ry is offline   Reply With Quote
Old 12-22-2011, 08:42 AM   #16
MonkeyBoy668's Avatar
Icon3 Re: brakes making hissing sound when braking
Check the dates, ludedude48 is a necroposter. And he's asking about a problem with a TL in the 92-00 Civic/Del Sol forum.
MonkeyBoy668 is offline   Reply With Quote
Old 01-25-2014, 06:32 PM   #17
swizz977's Avatar
where exactly are you supposed to put the brake grese
Old 01-25-2014, 06:36 PM   #18
I never narc'd on nobody!
NotARaCist's Avatar
2+ year old thread...for a question that Google can answer. Don't do that. Rear of the pads, and on the caliper sliders.
NotARaCist is offline   Reply With Quote
EP3 Brakes on EK heunde Honda Civic / Del Sol (1992 - 2000) 2 06-12-2009 03:13 PM
bleeding the brake xaznxdrgnxboix Honda Civic / Del Sol (1992 - 2000) 1 06-06-2007 02:17 PM
How to brake flush? acchaser Honda Civic / Del Sol (1992 - 2000) 20 10-08-2006 01:19 AM
WTB - brake pad holders B-series srg For Sale 0 07-06-2006 05:01 PM
smallest rim on gsr brakes Mr. Softee Acura Integra 3 12-25-2001 05:59 PM
Tags
boise, brake, brakeing, brakes, braking, caliper, civic, hissing, hit, make, making, noise, rsx, sound, uk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
