brake question's for Ek Hatch
Old 03-02-2005, 10:41 PM
ek9800's Avatar
Default brake question's for Ek Hatch
I'm looking to upgrade my brake's. I currently just have the stock brake system on my 1998 hatch. I wanted to know what's a good Direct/bolt up swap brake system for my car. It's non abs, I heard many different thing's, so can someone clarify to me what's a good direct brake swap. Thank's in Advance.
-Bryan
Old 03-02-2005, 10:51 PM
SOHC4life 96's Avatar
Default Re: brake question's for Ek Hatch (ek9800)
99-00 Si rear disc conversion. ITR MC/BB and if you have a DX you don't need a prop valve. If you don't, get the prop valve outta a 96-00 DX hatch or 99-00 Si. Then get ready to stop on needle point.
Old 03-02-2005, 10:57 PM
ek9800's Avatar
Default Re: brake question's for Ek Hatch (SOHC4life 96)
sorry frogot to Mention it's a CX
Old 03-02-2005, 11:52 PM
h22John's Avatar
gee this is a broad question with many answers. Why do you want better brakes? Answer that and youll get much better info.......not that the previous reply is bad info, it's very good but theres many more options......................john
Old 03-03-2005, 12:39 AM
Mugen x EK's Avatar
Default Re: brake question's for Ek Hatch (h22John)
your best bet is going to be gsr/si front/rear brakes as previously mentioned
Old 03-03-2005, 01:02 AM
ekb16's Avatar
Default Re: brake question's for Ek Hatch (twotoepowerbyspoon)
integra type r 5lug conversion
Old 03-03-2005, 04:50 AM
JOHN WAYNE's Avatar
Default Re: brake question's for Ek Hatch (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">integra type r 5lug conversion </TD></TR></TABLE>
i'd have to agree with that... if you have the cash.
regardless of 4 or 5 lug, you should also upgrade your front brakes along with the rears. you want to have balanced braking and you will also need a 99-00 Si MC/booster (which i have for sale) to really take advantage of the bigger calipers.
oh i have the prop valve too.
Old 03-03-2005, 05:11 AM
pdiggitydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twotoepowerbyspoon &raquo;</TD></TR><TR><TD CLASS="quote">your best bet is going to be gsr/si front/rear brakes as previously mentioned</TD></TR></TABLE>
INTEGRA brakes are different than em1 si front calipers. INTEGRA front brakes are larger.
Hatches have the same prop valve as the em1, so you dont need that when changing to rear disc.
To get larger brakes up front you will need the ex/em1 si/abs civic knuckles. With those you can use ex/em1 si, INTEGRA/abs civic, type r, or nsx/legend front brakes.
Old 03-03-2005, 05:41 AM
Bull's Avatar
I track (high-speed lapping events) my 96 b16 swapped hatch regularly. I went with Cobalt rotors with Axxis Ultimate pads in the front, rebuilt the drums in the rear and upgraded the brake shoes and went with ATE Superblue brake fluid. I have yet to experience brake fade and haven't had a need for more braking power in 30+ minute lapping sessions with repeated braking from 100+ mph. I'd start there first . . . you might find yourself happy with a simple cash outlay of less than $150.
Old 03-03-2005, 06:26 AM
alltech_hybrid's Avatar
Default Re: brake question's for Ek Hatch (Bull)
99-00 civic si rear disk directly bolts up and its a great mod if your strapped for cash
Modified by alltech_hybrid at 10:11 AM 3/3/2005
Old 03-03-2005, 06:41 AM
...all rear discs are the SAME!!!!!!
Old 03-03-2005, 06:47 AM
EK-Chris's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">...all rear discs are the SAME!!!!!!</TD></TR></TABLE>
Yes they are I have Del Sol rear brakes on my Ek...
95_GSR_SEDAN
29
11-15-2009 12:21 PM
Integralove00
09-10-2006 08:59 PM
eg94si
11
08-06-2005 05:44 PM
length
08-31-2004 03:59 AM
X2BOARD
10-02-2002 09:08 AM
Quick Reply: brake question's for Ek Hatch
