Brake problem or bad tie rod?
Old 08-02-2002, 04:29 PM
Turbo Powa's Avatar
Default Brake problem or bad tie rod?
This started happening today. I drive and when I brake hard its ok.... once I slow down to about 15-5 MPH and apply my brakes I start to hear a clicking sound on the left front side. Brakes are good and car drives fine but does anyone know whats going on? Tie rods were fixed in April. It is now four months and there aint any way that the tie rods are bad unless I got hustled by my mechanic. Does anyone think it might be the break pads? Could it possibly be that I may need more brake fluid? I have no knowlegde of this and hope u guys can help me out!!! Thanks!!
Old 08-02-2002, 04:53 PM
Turbo Powa's Avatar
Default Re: Brake problem or bad tie rod? (Civic LX 29)
Anyone????
Old 08-03-2002, 04:14 AM
VWkila's Avatar
How loud is it, and are you sure it only happens when you break? How about when your turning? Or when you hit a bump?
Old 08-03-2002, 06:34 AM
LilDevil's Avatar
Default Re: Brake problem or bad tie rod? (VWkila)
I'm experiencing the same problem.. check out my thread and tell me if it sounds familiar. https://honda-tech.com/zerothread?id=244913
Old 08-04-2002, 07:29 PM
Turbo Powa's Avatar
Default Re: Brake problem or bad tie rod? (LilDevil)
No metal bending sounds. The sounds that it makes is the same when you drive in the rain and your break pads get wet and you slowly let off the break it makes that noise. Its the same noise except it happens even if the pads did not get wet. Any suggestions?
Old 08-04-2002, 09:27 PM
ED8DX's Avatar
Grab the tire and try to move it, (i.e. see if it wobbles) it could be your ball joints. The same thing happend to me and it turned out to be the upper control arm ball joint.
Old 08-05-2002, 05:36 AM
SuPeR_MaN's Avatar
Location: Quezon City, The Philippines, The Philippines
Default Re: Brake problem or bad tie rod? (ED8DX)
check also if you already need some greasing. it's the tie rod end if it creates a knocking sound when you turn the steering wheel.
Old 08-05-2002, 03:47 PM
Turbo Powa's Avatar
Default Re: Brake problem or bad tie rod? (SuPeR_MaN)
i'll try it out. thanks
Old 08-05-2002, 03:49 PM
DragII's Avatar
check your cv boots as well.
CHu Chu
06-06-2009 12:03 AM
inxekure
10-22-2008 05:29 AM
Mfoehrkolb
09-25-2008 06:45 AM
Turbo Powa
08-05-2002 12:05 PM
GSxRated
07-14-2002 05:52 PM
Quick Reply: Brake problem or bad tie rod?
