brake pelal slowly goes to floor with a/c on when at stop lights.
Only when the A/C is on, so is it a vacume issue? I figured that would be the only thing it could be. Also................
My a/c needs service and isn't very cold right now. This is my first car with a/c. I'm told when it does not get cold, it's most likely a leak in the "high side" of the a/c system. That little bit of info is over my head, but could that leak be cuaseing this to happen? Help me out here guys and gals. Throw me a bone.
Re: brake pelal slowly goes to floor with a/c on when at stop lights. (K SERIES)
MY bet would be on a vaccuum leak. Also keep in mind that if your breaks need to be bled then they will "soft" in a high heat enviornment.
1 Post
Re: brake pelal slowly goes to floor with a/c on when at stop lights. (egsi)
Wow.
Chances are that if you had a vacuum leak you would be throwing an O2 code that you are running too lean. Rule that one out.
If it was his master cylinder why is it only doing it when the ac is on? rule that one out.
As for your a/c, there could be a leak anywhere. One problem with this is that part of the system is called an accumulator dryer and it houses a dessicant bad which removes moisture from the system to help protect the compressor because as I'm sure you know liquids do not compress. When the dessicant bag is open to the air it saturates in a matter of seconds. It is always a good thing to replace if you fix a leak in your ac.
Re: brake pelal slowly goes to floor with a/c on when at stop lights. (JDM-97CX)
I was thinking of it more from a standpoint of ambient heat....not really from the whole AC thing. He's goign to be running the AC when its extra hot out plus its goign to put load on teh motor at idle.....which will not help the build up of vacuum in the master cylinder. Of course there's always the chance it could jsut be a leaky secondary cup seal.
A vacuum leak would have the opposite effect, it would be harder to push the brakes since it would take away from the vacuum assist for the brakes.
The a/c could be a number of things, its probably a leak. I'd check around the condensor, look for sticky tar like stuff stuck to the fins. A/c systems have a small amount of oil in them so look for it around fittings as well.
brokenojoke
07-28-2005 10:44 PM
