Brake lights dont work HELP ME
Old 02-23-2009, 08:19 PM
djsimm89's Avatar
Icon2 Brake lights dont work HELP ME
ok honda-tech heres my problem just picked up an eg coupe my brake lights dont work but my runing lights work cnecked my fuses there fine then removed the brake switch on the brake pedal and checked the plug there is no power going to the plug so wtf do i do help me out
Old 02-23-2009, 08:25 PM
Former User's Avatar
Default Re: Brake lights dont work HELP ME
Check for battery voltage at fuse 42 (20A) under the hood. If there is power at this fuse, then the Wht/Grn wire running between fuse 42 and the brake switch has an open.
djsimm89's Avatar
bump ttt
djsimm89's Avatar
what u mean by an open?
Old 02-23-2009, 08:29 PM
H-T White Ops
NOFX's Avatar
Does your horn work?
What year and body style? This can help.
Old 02-23-2009, 08:30 PM
KillBot's Avatar
open = grounded = bare wire insulation = bad wire
Old 02-23-2009, 08:32 PM
djsimm89's Avatar
heres a pic o my under hood fuse box it has nothing for my brake lights
Old 02-23-2009, 08:33 PM
djsimm89's Avatar
its a 1993 i just picked it up came wit a ls motor and i think they had it converted for power windows and locks if that helps
Old 02-23-2009, 08:36 PM
HT White Ops
Eran's Avatar
[ stop horn ]
It's the fuse labeled Stop/Horn = fuse 42
Old 02-23-2009, 08:37 PM
djsimm89's Avatar
good looks ima look at it now
Old 02-23-2009, 08:38 PM
KillBot's Avatar
Lamp De Stop
Old 02-23-2009, 08:41 PM
djsimm89's Avatar
ight i checked the fuse just now its fine
Old 02-23-2009, 08:45 PM
As asked by NOFX, does the horn work? If so, test for continuity for the Wht/Grn wire between fuse 42 and the brake switch.
Old 02-23-2009, 08:50 PM
djsimm89's Avatar
the horn wire is cut check the pic
djsimm89's Avatar
that lil wire is my horn wire cut
Old 02-23-2009, 09:00 PM
Remove fuse 42 and then check whether the battery-side terminal (red arrow) for fuse 42 has battery voltage. If so, then the Grn/Wht wire is broken somewhere along the red line.
Old 02-23-2009, 09:04 PM
djsimm89's Avatar
ight good looks ima check that tomro mornin
Old 02-24-2009, 10:54 AM
djsimm89's Avatar
problem solved
Old 02-24-2009, 11:17 AM
Pothole987's Avatar
what was the solution? always good to know...
Chris_A
07-28-2017 08:54 AM
Hakuna33
11-30-2009 12:56 PM
cmyrex
07-12-2006 04:27 PM
mechanik
06-14-2002 05:41 PM
mechanik
06-14-2002 05:38 PM
Quick Reply: Brake lights dont work HELP ME
